Richard Finch is a friend of mine, and asked me to post this response for him:
Richard Finch EAA, AWS, SAE
Regarding the right welding rod to use when TIG welding 4130 steel ............. The big manufacturers, Lincoln and Miller, don't recommend anything but the rod they sell, read this again and again. They don't recommend any rod that they don't sell, but in private and in their schools, they recommend Vacuum Melt, Metallurgically Controlled 4130 rod for the best results. Any Lincoln or Miller rep who tried to steer you away from rod they make and sell, would loose their jobs immediately. Miller and Lincoln don't make VM, MC grade 4130 and therefore can't recommend what they don't make. But they SHOULD MAKE IT !!
The fact is, read my two books, "Welder's Handbook" sold at Lowe's, Home Depot and Sears stores for $16 and read my other book, " Performance Welding" sold by Motorbooks International at $25. I am very plain about the proper choice of welding rod that is best to use for TIG welding 4130 steel. If you can't afford the two books, check them out in a library or on the web site at Amazon.com.
About the higher cost of VM MC grade, 4130 rod, it will cost about $25 to weld up a Super Cub engine mount , using the best rod versus only $ 2 for the cheap stuff RG60, etc. If you can afford a Super Cub, then the good welding rod should not be a factor.
Just this morning I used my Lincoln TIG welder and VM, MC Grade 4130 rod to make a repair on a homebuilt Nesmith Cougar, and the rod cost me less than $1 for the entire repair. Cost should not be a factor in maintaining your very valuable Super Cubs.
Regards,
Richard Finch, former PIPER Aerostar welder, and book author with a Masters degree in aeronautical engineering....
