Bill Rusk
BENEFACTOR
Sandpoint, Idaho
To All
A while back I made a post and talked a little about Square Corners. Some folks suggested a thread on that topic so here we go.
First a little about the term "square corner". In the fighter world we talked about getting into a firing position on an opponent. You had to get within a certain cone at your adversaries 6 o'clock...BUT....you also had to be pointed in roughly the same direction as his flightpath in order to employ ordinance. You could not just fly to his six and be 90 degrees off his direction because the airplane can't make a square corner. Airplanes, even F-16's can't make square corners....thus the term. The term can be, and was, expanded to include just about any situation where you are asking the airplane to do something it just can't do, like make a square corner.
This was my first post on the topic.....
I lost a cohort recently and it turned on a light for me. He was a very experienced pilot, ex military fighter, current airliner, active in GA and in the CAF, in short he had the skills, knowledge, and probably a fair amount of judgement. He took off at an airshow, giving a ride in a 180hp Supercub, and did the max angle climb thing. I don't know if he stalled, or the engine hiccuped, but at that angle, altitude, and airspeed there is just not enough air under you to recover. The airplane is going to freefall for awhile because there is insufficient airflow over any of the control surfaces to make them work. About the time you can recover you hit the ground. It does not matter how quick you shove the stick forward at the first hint of a stall, it is too late.
The golden nugget for me is that every airplane has "Square corners" that if you get into you can't get out of.
I knew this, but it just got refreshed in a big way.
The F-16 didn't have many but it did have a couple, it also had an ejection seat that would get you out of a lot of those square corners (the airplane might not make it but you would). The 737 has a LOT of square corners. The Cub is so fun, honest, and good it is easy to overlook them. In fact, my initial response upon hearing of this accident was "How can you possibly kill yourself in a cub unless the wing falls off?" Bad mentality on my part. Answer....the Cub has square corners too. This is one. Don't go there.
So while I have enjoyed "spanking" a few Cubs on takeoff in the past I think I'll round off that corner in the future.
Thanks for listening.
Another Square Corner
Sink Rate
As you practice the steep slip, to a landing over the proverbial trees, remember that you can develop a sink rate that you may be unable to arrest before ground impact. Where this will bite you is.... you go out and practice an aggressive slip right to the flare, where you stop the sink rate, flare with no float and plop down. Perfect, except that you practice solo. When you increase the gross weight by adding your buddy and all your gear, you must increase the energy and altitude enough to stop the sink rate and greater mass on the vector. You will get wings level and may even get the nose pointed up but the plane (and its vector) will still be going down and you will hit the ground HARD. Generally sink rates in cubs are not a big problem, but they can happen, especially when you are heavy. In fighters, airliners and high performance aircraft, (Lancairs, Glassairs, the new VLJ's etc.) the issue of sink rates on final approach is critical and once you allow it to develop it becomes a square corner. No amount of pilot skill or thrust will get you out of this corner. You will crash. The airplane can't do a square corner. So.....be careful of developing a high sink rate close to the ground and don't get yourself into a square corner.
Sink Rate
