CaptFox
Justin, TX
HELP!
I was trying to spray some silver (Poly Spray) today on a Horzontal Stab with a Graco HVLP with the gravity cup. I had no problems with the Poly Brush Spray coats earlier in the week. Today I could not get anything to come out properly. I tried #3 and #5 tips both with similar problems and I either could not get anything to come out of it or it would come out in in a stream or splatter. When I did seem to get the spray pattern and flow set up correctly between the air and fluid settings it would spray one or two passes and then stop. I finally has to give up for the day.
Anybody have any suggestions? I'm assuming this is a operator problem not an equipment one? I did run out of time and light today so I'll have to trouble shoot more next week. Anybody have any similar problems or any setup advise before I tacke this.
David.
David.
