Darrel Starr
Plymouth, MN
Yesterday I found and watched the following video http://www.youtube.com/watch?v=QtokU8mIDQk
My tailwheel springs were too tight like the example of the wrong way to set up the tailwheel. I have the AN42-6 eye bolts already and have ordered the 1/8th inch "U" shaped "Quick Links" from West Marine like the ones in the video as used on Maules.
But I have another issue. I have no instructions and no idea as to the correct detent force and how to reset the detents! Help!
My Scott 3200 tailwheel is only 70 hr old. The detent to the left as I am sitting behind the tailwheel seems about right. About like the force required in the video once the chains are loose. But I have no force specs to figure this out. The detent to the right is BARELY discernible. Just a minor bump. How do I increase the detent force to the right without messing with the value of the left detent force? I have searched for Scott info on the Internet and they seem to be missing in action. AKBushwheels sells a service to rebuild these so it seems they also don't publish any instructions. I have used Google's advance search to look at old Supercub.org threads with no joy.
That leaves me on my own unless someone out there has a set of instruction they are willing to share as to 1) what is the correct force value for the detent and 2) How can I rework my tailwheel to get there, Left and Right. Thank you for your consideration.
Darrel
Darrel
