I had a landing mishap in My experimental Wag Aero 2+2. It was more than a ground loop and resulted in the right gear ripping off, a prop strike, and a scraped wing tip. The brand new Superior engine is OK - checked the prop flange and checked OK. The wings and struts also OK -nothing bent, nothing wrinkled, controls OK. Only lower part (lugs) for attaching rear landing gear leg tore off. Wing strut portion of bracket looks OK. Can I weld on new bottom "U" shaped lug or replace whole bracket. If replacing whole bracket can it be removed and ground back to original tubes or does whole tube cluster need to be replaced. I am considering replacing the gear on both sides with Atlee of Airframe extended gear. In consideration of experimental aircraft versus certified aircraft should attach bracket that ripped off be replaced with lower repair, all new bracket or all new brackets all the way around? Any opinions would be greatly appreciated. Chuck H.
