I have a really basic question (and after I got to writing, some follow ups also) on rear-mounting the oil cooler. It seems that a lot of attention is paid to good baffle seals inside the cowling, yet an oil cooler makes a pretty big hole - a substantial shunt for the available airflow. It seems to me that the oil cooler mounted on the rear baffle robs a considerable amount of cooling air from the cylinders, because the cross section of the cooler is a considerable percentage of the cross section of the cowl air inlet. However the front mounted cooler uses an air supply that is separate from, or in addition to, the supply to the cylinders.
So - it would seem that if high ambient air temps are expected, the rear-mount cooler might not be a good idea??
And it would seem that, as a minimum, CHT sensor(s) should be on the same side of the engine as the cooler to probably show the highest temp? Is that required? Am I all wet???
Also, what is the advantage, other than a tiny CG change, a cleaner looking nosebowl, and lack of cooler/nosebowl chafing as a result of cowl misalignment, of mounting the cooler in the back in the first place? I've never understood a good reason to make the change, and I'm wondering what I might be missing.
One more question, are there any problems with fatigue cracking of the rear baffle with the cooler mounted on it? (or does the STC require some structure other than the baffle for mounting?)
