I am rigging my plane now. I have installed the univar lift struts. There is a small clamp, appox. 1/4-3/16 in dia. with a screw hole in it to tighten. Where do I get the fairlead for this? Is there a part number?
Just did mine, and it was 3/8's x 3/8's. Old one was wood. Or, you could make one out of a piece of nylon rod. One-piece if you string on to the cable before attaching the hardware on the end of the cables. Or, split it (like the larger fairlead lower down on the strut) when you forget and attach the cables before putting the fairleads in.
