WindOnHisNose
BENEFACTOR
Lino Lakes MN (MY18)
I value the knowledge of you all, and would welcome comments regarding a problem I am facing.
*I have just taken my CT210 in for annual and have to make a decision regarding the engine. *I fly about 250 hours/year, flying once per week, generally. *I put a factory reman TSIO-520L into the aircraft in July of 2005, found the compressions low in 3/6 cylinders in 2007, having a top overhaul performed with factory new cylinders (under warranty) at 450 hours TTSN, then had low compression in #4 in 2009, sending that in for repair, then #1 in 2010, sending that in for repair. *The general pattern is at about 400-500 hours one or more cylinders lose compression.
The repairs to #1 an #4 were done at a local shop that has an excellent reputation and I know the owner, Darell Bolduc, quite well...he is the most respected engine man in the upper midwest. *I asked him if I am doing something wrong, and he said he didn't think so. *He told me that this scenario would have been unusual 15 years ago, but that they see this exact thing on most Continental engines, particularly turbocharged ones, since then. *He feels Continental uses an inferior metal alloy now, and that this is the likely problem. *I might also add that I have GAMI injectors installed and have run 50 degrees rich of peak, and 50 degrees lean of peak, but both have resulted in cylinders that lose compression.
I just found out that my engine, at 1100 hours TTSN, has cylinders with compressions of:
#1 63/80
#2 18/80
#3 62/80
#4 60/80
#5 5/80
#6 2/80
Obviously, I need do a top overhaul, vs replacing the engine. *Given the history, I am going to likely do a top overhaul.
The first question I have is where should I buy the cylinders. *Options, in order of recommendation by Darrell Bolduc's shop, include #1, Millenium; #2 Factory new; #3 ???
What would you suggest?
The second question is related to how I run the engine. *I fly at least once per week, the aircraft is hangared, generally, but when I fly to Minot, Bismarck, Fargo, etc, I plug it in to let the Tanis heater do it's thing, cover the engine. *I always let the engine get up to 100 degrees F before initiating flight. *I have run 50 degrees rich of peak, generally, but have been told by some that this is a bad place to run the engine. *Darrell feels that running lean of peak is the way to go and I have done so with the GAMI injectors in place. *Do you have any suggestions?
I appreciate any feedback. *The CT210 is a critical part of my medical practice, using it to deliver care to people living across the upper midwest, and I baby this aircraft. *Thanks for any input.
Randy
#1 63/80
#2 18/80
#3 62/80
#4 60/80
#5 5/80
#6 2/80
Randy
