Once one starts modifying the OEM designed airflow through the engine compartment, one requires good feedback (data) from its effects on the engine. Typically, a fully probed temperature system for all cylinders provides this data. I ran stock Cessna winterization covers (aka block-off plates) for 15 winters in interior Alaska with a UBG-16 providing the data I deem a requirement for proper care and feeding. I ran my 0-470R to TBO twice (BJ overhauls in Palmer, yes, Bob has retired to the lower 48) and now on a third with the preponderance of operating hours in sub-zero temps. No cylinder replacements between overhauls. Our work required multiple climbs to 10-12K followed by descents to the surface. IMO the reduction of cooling flow to the engine is a requirement for this mission profile while operating in sub-zero temps. (Failure to reduce intake combustion air results in lean mixture as well)
As for cabin heat, its relative. The ram air is reduced by the winterization plates. Running with the cold air door partially open definitely helps but obviously reduces the temperature as it dilutes the heated air. When operating in colder than -20F I fitted an adapter I made into the right-hand floor outlet ahead of the doorpost and ran a piece of 2" SCAT (about 6') so the rear seat occupant could clear the side windows as when descending into colder temps (typical inversions) resulted in the windows frosting over on the inside. My self-induced no-go temp was -35F, however, the coldest I saw airborne was -45F letting down into the FortyMile drainage east of Fairbanks. It was not possible to keep the windows clear at that temp and the forward visibility was only through the little frost-free hole provided by the defroster. Not a hospitable operating environment and I did not linger.
I am just sharing my data ref cold weather engine care and feeding (well over 3000 hours on this one engine operating in mostly sub-zero temps with zero issues. This worked for my mission, yours may be different. Just providing a data point, no other agenda.
TR
