PerryB
Chico, CA
I just balanced my new Catto and am very happy with the result. A brief backstory: About a year ago I had my Borer reconditioned and bumped up to 42" pitch. It was tracked and statically balanced as part of the procedure but was not as smooth as it was before the work, so I took the plane to a man in Jackson,CA. and had it dynamically balanced on the engine. The improvement was significant. I don't remember the starting number, but we got it down to .04 in/sec.. I noted a static improvement of about 30-35 RPM and no more buzz through my heels. The climb-out RPM also improved slightly, for a given airspeed (at full throttle of course).
About 2 weeks ago I got my new Catto and really like the prop. Its an 82-39. The pitch is perfect for what I want. Takeoff and climb is identical to the Borer and cruise is about 3 mph faster for a given RPM. It felt pretty smooth but not as good as the aforementioned Borer with its balance job. Today I borrowed a Dyna-vibe ( the man from Jackson moved away but I found another fool to trust me with his equip.) to see how far out it was. I was rather shocked to see .38 in/sec. I guess the Catto soaks up some of the vibration and spreads it over a greater part of the arc, because I think a metal prop at .38 in/sec would feel like a tuning fork. Anyway, I got it down to .07 in/sec and called it good. I think its now the smoothest 4 cylinder I've ever operated, and I got the same 30-35 RPM increase that I got with the last balance job. I guess the construction/composition of the Catto will dampen the vibration, but it can't hide it from the accelerometer.
At this point I'm completely sold on dynamic balancing, regardless of how smooth a prop feels.
P.S. When going from an 82" Borer to an 82" Catto deduct 3" from the pitch. The Catto has more blade area and probably a more efficient airfoil. My static RPM's are identical, the takeoff distance and rate of climb are as close to identical as I can determine (including WOT brake release time to 1000' agl) but if forced to declare a winner in this dept. it would probably be the Catto. On the top end the Catto runs out at 2730 RPM and 106 vs. 2700 and 103 for the Borer, and as mentioned above it runs about 3 mph faster for a given cruise RPM. -- Hope I haven't bored anybody to death, but I found it to be an interesting and educational experience.
