jon s. blocker
GONE WEST
corpus christi, tx
I am building a new fuselage and want to box the tail section. I have seen a simple X, I have seen a box from lower longerons to the diagonal above that longeron, I have seen a box from the lower longeron up to the middle longeron. Any opinions on which is the best method? Is a simple X good enough, or is it best to make one of the previously listed boxes? It will be a PA11 type fuselage. I am putting a Lyc 0290D on it. It is beefed up in front as per Wag Aero plans. The firewall is kicked forward to put the thrust line to zero degrees, Balanced PA20 tailfeathers, no electrics. Very simple, as light as possible. Any suggestions on the boxing of the tail would be appreciated. Thank you, Jon
