BENEFACTOR
2.25" looking at my original weight and balance on my Super Cub. 2" on the TCDS, I guess that shows how unimportant it was to Piper.
so if most cubs are at 1200lbs that compete at valdez, then my modified 160hp, pa12 weighing in at 1217lbs is good???Soooooo. Did you watch them weight the plane. How was the fuel removed? Did you use the same scales? Had they been calibrated recently? Was the plane weighted in flight level attitude both times? Did you weight the parts you took off and the parts you put on or just go by paperwork? Did they leave something in the plane on last weight in. (Under seat storage/baggageares/pod/seats/map pockets. Unless you have calibrated scales and the same people doing the weighting without you watching who knows. How does it fly? Can you tell the difference between 6 and 12 gal of fuel when flying? Most of the cubs winning Vadez are in the 1200 lb class.
So Dave, Which of the two is correct? The original Piper W&B or the TC? If the original sheet isn't available, I would go with the TC.Steve, does it change when you put extended gear on? Never worked on a Cub with extended gear, just curious.
I was thinking of using the 2" as a means of leveling.When I do a weighing
That is a great weight for a Modified 12 especially if you have big wings.so if most cubs are at 1200lbs that compete at valdez, then my modified 160hp, pa12 weighing in at 1217lbs is good???
Let me try to explain. There seems to be a disagreement of whether the dimension should be 2" or 2.25", which appears to depend upon which "official" document is used as a reference. My use of 2" is based upon the FAA's TC data sheet where it gives the arm of the main tires as being 2", thus the axle center. This number is used solely as a means of leveling the airplane by dropping a plumb bob from the wing leading edge and measuring back to the axle center line 2". All of the equipment items on the TC 1A2 have an applicable arm published. This arm is applicable when the main tire center line is 2" aft of the WLE datum. If 2.25" is used for the distance, should all of those TC arms be increased by 0.25"?I don't understand skywagons questions of 2"? I am using the 2.25" of the wheels aft of the wle per Piper's drawing. But, I am NOT using the 186" aft of the wheels as an arm which is at the rudder vertical post, but rather the axle of the bushwheel, which is an additional 16" aft of the rudder tail post, for the arm as that is where the scales were located making a total of 204.25" aft of the wle. But that is for the cg, of course. I am still concerned of the weight but there is nothing more I can do for that except to get the correct figure as I have a ton of lightweight mods now. Weight increases stall speed which then increases takeoff and landing distances. The whole idea of a super cub is very short take off and landing distance which drew me to the plane initially. But, of course, it's still fun to fly but I'm always looking for funer.
.....My use of 2" is based upon the FAA's TC data sheet where it gives the arm of the main tires as being 2", thus the axle center. This number is used solely as a means of leveling the airplane by dropping a plumb bob from the wing leading edge and measuring back to the axle center line 2"....
..... All of the equipment items on the TC 1A2 have an applicable arm published. This arm is applicable when the main tire center line is 2" aft of the WLE datum. If 2.25" is used for the distance, should all of those TC arms be increased by 0.25"?....
.....When actually weighing the airplane there should be prolific use of plumb bobs and tape measures for all data points. When calculating additions and subtractions, the numbers in the TC ought to be used. Or if all the numbers are listed on Piper original sheets, use them. Don't mix the two.
Yea 18” extended, alerons moved to the tip, 8’6” flaps, 4 position flap knotch, Charley Centers leading edge cuff, CC wing tips with fence, CC mid wing fence, atlee tie downs, all new wing except spars, but built with Dakota cub parts, my big saving is fabric interior and the Oratex fabric. Still havent installed the vortex generators but least they r powdercoated. HahahahaaaaThat is a great weight for a Modified 12 especially if you have big wings.
When the plane is leveled with the PK screw and the punch mark (if you can find them), the main tire arm is +2" per the TC. Therefore, by dropping a plumb bob from the leading edge and measuring 2" to the main axle.....the plane will be level. PK screw and punch mark not needed.I disagree.
Fron TCDS 1A2 (for Piper PA18):
"Datum: wing leading edge
Leveling means: plumb from PK screw in upper door frame channel to center punch mark on enclosure door rear hinge"
All of the arms called out by the TC assume the airplane is level. The main wheels will be at +2" if the plane is level. If another dimension is used, the plane will not be level in accordance with the TC. It would take some complicated (to most) mathematics to figure the difference from the published numbers, which would also necessitate the consideration of the vertical location of the item. Granted, the differences will be slight.I say no, they will not change. MLG wheels can be at 2", minus 2", or wherever-- doesn't matter.
The TCDS calls out the arm of everything from the datum, which is the WLE.
When the plane is leveled with the PK screw and the punch mark (if you can find them), the main tire arm is +2" per the TC. Therefore, by dropping a plumb bob from the leading edge and measuring 2" to the main axle.....the plane will be level. PK screw and punch mark not needed......
I always assume an unmodified airplane when using the data on the TC.That's assuming stock leading edge & stock gear.
Both are often modified, as in a cuffed leading edge & extended and/or raked gear.
When actually measuring, the firewall is an excellent reference. Take into consideration the thickness of the firewall blanket. Make certain that information is documented in the paperwork you generate and the difference between the firewall and the "approved" datum is noted. Someone later down the road may use the numbers in the TC causing the W&B information to go down hill.The nice thing about using the firewall for a datum is that I'm not aware of any mod that moves it fore or aft--
unlike the landing gear or leading edge.
Unlike PK screws & prick punch marks, I've never failed to find the firewall.
And it's super-easy to measure from-- esp inside the fuselage.
What will you use for the seat, baggage measurements and the cg of the fuel? Those are dependent upon a average center of gravity of a body or baggage. When you change a datum, there are many other changes which must be made and documented.
Yes the Cessna 180 does use the firewall, other planes don't. Keep it simple, rather than confusing the next guy.
