I'm getting constant noise in one side of my intercom music circuit(s) that seems to be coming in via the 796. It is a constant low pitch static, not like an alternator whine and it does not change with RPM.
Installation particulars:
As I said the music circuit make a constant static roar (XM Antenna plugged in or not) but plug in a phone jack (phone or not) and all is clear.
What I have done so far:
Looking for brilliant ideas, support groups or an intervention...
Many thanks,
Kirby
- Super Cub panel with all a surface mounted 796 using all Garmin hardware and wiring to the fuse holder, from the fuse holder pigtail to the breakers is a soldered and shrink-wrapped standard aviation wire with no other splices.
- Sigtronics Intercom.
- XM Antenna that I move from plane to plane but the default location is not the Cub so this may have been going on awhile, but I've been noticing for better than a couple of years, but it had gotten worse.
- I like to fly with tunes so there is a mini plug for music that is internally switched (2) for two sources, XM is constant, and it magically overrides XM when you manually plug into it and connect your phone.
- We relaced the music plug with the same (SWITCHCRAFT INC PN 35RAPC4BH3) and the static got better, perhaps reduced by 30% but it is still seriously annoying, before it was a roar.
- After flying with the new music plug in place and still having static without a mini plug plugged in, I made further attempts to isolate the noise. I again turned things off and back on and started pulling breakers with the engine running as you don't hear it otherwise and that's when it got interesting. Turning off the Trig Mode S (with Trig ADSB out) transponder makes no difference but pulling the Transponder breaker and all went quiet but the 796 went into battery mode so it was obviously on the same breaker.
- Thinking the common breaker with the transponder was the issue we moved the 796 to a different breaker. Tried that and no change in the noise, it's there anytime there is no music jack plugged in (I Phone connected or not) and pulling the transponder breaker makes no difference so I don't think that's the culprit, but who knows.
- Also, after moving the supply to a different breaker, I pulled the in-line fuse to the 796 and the noise went away.
- Pull the 796 and no noise, put it back in and noise.
- Pull the Transponder breaker and still have the noise.
- Swap the 796 with a different unit and same issue, so it's not the unit.
Many thanks,
Kirby
