Results 1 to 22 of 22
Thread: Bushwheels vs Props.....a twist on old threads
    Feb 2015
    Anchorage
    19
    I'm heading the opposite direction of most people and am going to fly the Cub down to Oregon and do a couple weeks in Eastern Oregon and Idaho in late July.
    To make a faster trip I was thinking about swapping out the Borer prop for the stock 74/56 prop or possibly the 31's and going 8.50's. With 31's and a 43 pitch Borer I'm truing out about 90mph. With my fuel pod I can almost make KTN-BLI on a nice day down the coast if its open...and that would be my goal if I can do it. That way I can get the trip south down to possibly 2 days if all goes perfect.
    I can ship the stuff down with me for free that I take off....or just fly it the way I bring it down.
    My question is what are the performance gains/losses anyone has experienced doing this? No reason to invent the wheel, and I know I'm not the first person who has thought about this.
    Thanks.....Brett
    55-PA18A's Avatar
    Dillingham, Alaska
    578
    I don't have any answers, but thought about it myself when I flew down from AK. Will be interested in the responses. This thread might also be a good place for any other possible temporary speed mods.
    G44's Avatar
    Oct 2011
    SW Michigan
    394
    Quote Originally Posted by md11freighter View Post
    Thanks.....Brett
    Just get a Husky, problem solved.
    spinner2's Avatar
    Montana
    1,710
    This past winter I put on my LW2500 skis with 8Ē tires. I left the little tires on for a few flights after pulling the skis a couple of weeks ago. But I kept the Burlís tail ski on. The difference in cruise speed was 4-5 mph over 31s and a Baby Bushwheel. So it would be all of 5 mph Iím sure, had I replaced the tail ski at the same time I pulled the wheel penetration skis.
    I donít remember pulling the skis before and not also changing to 31s at the same time, so this was a good comparison.
    I have a Catto on an O-340 so canít compare props and engines but drag difference should be the same.
    This is was some very hard snow in January but shows the skis well. With these skis on, Iím probably a couple mph faster than 31s. Not much, but for sure a little faster.
    G44's Avatar
    Oct 2011
    SW Michigan
    394
    All kidding aside Brett, having those 31's on when flying over beaches would be comforting in the event of a problem.
    Kurt
    tedwaltman1's Avatar
    Jul 2011
    Denver, CO
    360
    I did a Denver to Ames Iowa trip, 500+ miles ea way, twice two summers ago. First time on 6x8.5 tires and second time on 35” Bushwheels. Tried to carefully track speeds at the same power settings.
    Only approximately a 3 mph difference!
    3,207
    Quote Originally Posted by tedwaltman1 View Post
    I did a Denver to Ames Iowa trip, 500+ miles ea way, twice two summers ago. First time on 6x8.5 tires and second time on 35Ē Bushwheels. Tried to carefully track speeds at the same power settings.
    That's my experience also. 8.50's, Bushwheel 26's, and Bushwheel 31's - only a couple MPH difference. I REALLY want to do a controlled comparison of the three!
    Also - I covered my gear, without rear-leg fairing, expecting a noticeable improvement, and only realized about 1 MPH increase. Bummer!
    8,717
    In my opinion the prop change will make the greatest difference. The prop is only going to screw through so much air with each revolution. At some point it will not matter what size tires are on the plane. The prop will only pull it so fast.
    8,956
    Did your fuel burn change?
    When I had the 180 cub I would lose 4-5 mph putting on floats, but would burn 2-3 gallons more of fuel. The aircraft drag made the engine work harder, so more fuel for same rpm.
    When I switched to HD gear on the Maule, going from covered to open gear, it cost me about 5-6 mph. 35's about the same. One day I used gorilla tape and covered the gear and gained almost 6 mph! So for the trip, even with clear tape, cover the gear!!! (The Maule blew off the tape after 5 hours, but the cub speeds it should be fine.)
    I am doing the clacs now to fly to JC. What is the best way to go. Put baby tires and race quickly down? By the time I spend an hour switching tires I have made up the time with big wheels. Cubs are slower, but like said above, in an emergency- weather, engine, anything, the tires add a safety margin.
    While I realize everyone wants to save time and not stop in Canada, consider this- you can land in YPR, taxi off, call can pass on the cell and take back off. Last time it took me something like 5 minutes. You can not avoid going close to Rupert and stay near land. If you do get customs, then want to stop along the way for any reason- cramps, bathroom, oil temps looking odd; just do it. Once to BFI, you will have to dance around the rose bush and hope on one foot for clearance, but well worth it.
    For my purpose, I find Friday Harbor a much nicer place to check in, but don't know about fuel.
    A thought of visiting some place to go fly- Once you get to eastern Oregon, you will most likely be at a higher elevation, warmer temperatures, and different terrain than you are used to; comparatively, your performance will suck. Leave the plane as you know it, do the trip. The fewer variables you add to the mix the more you will be confident in what you are doing.
    My $.02- which I will pay you for when I see you some day!
    Feb 2015
    Anchorage
    19
    Sounds like a prop swap may be worth doing....or just go low and slow over Canada. I still have a few months to figure stuff out.
    thanks guys
    Jul 2011
    Denver, CO
    360
    Very wise advice George! I didn't track fuel burn--never thought to look at that for comparison purposes. That's amazing that you gained 6mph on the tape-over-the-gear. Wow.
    8,717
    Do you still have your gas receipts? It might be fun to compare the total fuel usage for the two trips.
    Feb 2004
    Mt.
    1,282
    I used to put a 74/56 prop and 8:50s on for Montana to Alaska and haul my Borer prop and ship or borrow tires or skis. Never bothered changing anything coming back because with tailwind at some altitude I could make it from ANC to MLS in 2 days easy wx permitting. Most cubs will pick up 10mph with both of these changes Iím my experience.
    Dave
    Jul 2011
    Denver, CO
    360
    Don't have the fuel receipts. Would be more "scientific" to do a say 100 mile x-c twice on same day and measure fuel burn that way. But I'm not that interested, as I suspect the differences are relatively minor (as was the airspeed difference). I'll burn a little more fuel for extra peace of mind that the big tires offer in terms of land (almost) anywhere.
    2,415
    ….. One day I used gorilla tape and covered the gear and gained almost 6 mph! So for the trip, even with clear tape, cover the gear!!! (The Maule blew off the tape after 5 hours, but the cub speeds it should be fine.)…..
    For my purpose, I find Friday Harbor a much nicer place to check in, but don't know about fuel.....
    Re covering the gear, maybe try using some of the saran wrap stuff that is commonly used for warpping stuff during shipping nowadays.
    Re customs, I've cleared 2 or 3 times at Friday Harbor, and they were jerks every time.
    I got a much better reception at Bellingham.
    All this was a number of years ago, so things may be different now.
    RaisedByWolves's Avatar
    Feb 2005
    3,668
    What happens when your flying cross country and have to pee? Youíll wish you had your big tires on
    Eddie Foy's Avatar
    Dec 2014
    3,144
    Motorman's Friend.
    https://www.amazon.com/Wearable-Inco...10547610&psc=1
    What happens when your flying cross country and have to pee? You’ll wish you had your big tires on
    DJ's Avatar
    Jan 2009
    Bolivia
    166
    I fly slow Cub but for what it's worth...
    6500ft msl
    Fuel burn 7.7 gph
    Leaned to the same EGTs values each time. Otherwise not very scientific.
    Catto 86/38 2500 rpm 84 mph
    Sen 76/54. 2450 rpm. 89 mph
    Sen 76/60. 2400 rpm 89 mph
    The 60 was a dog on takeoff.
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    606
    Quote Originally Posted by DJ View Post
    6500ft msl
    Fuel burn 7.7 gph
    Roger that 60" pitch is doggy on T/O.
    Used to always stick on 8:00x6 tires
    and a 74/58 when flying my old Cruiser to lower 48 from Alaska. It always was a solid 15mph over big tires and borer prop.
    When you would catch a Cub in Lake Clark pass on big tires n borer prop, they sure looked like they were tied, put puting along at 80/85 mph. As you
    breezed by at 110! Lol.
    Though in all fairness I realize that would never happen nowadays, as all
    Cubs with super flat, long props and 35" tires seam to be reported in the 100mph range.............
    Likes DENNY liked this post
    Feb 2005
    3,668
    Iíll fly next to you and show you I get 90-95 with big tires and prop
    AdirondackCub's Avatar
    Jul 2012
    Ballston Spa, NY
    132
    As for covering gear. Boat shrink wrap and the tape wrap that repairs holes or slices. Easy on, with the tape, shrink it and go
    Mark Keneston
    Cub Crafters
    Northeast Reagion Sales
    Ballston Spa, NY
    9,578
    I just took my skis off last weekend and have been flying around on my 22" 8.50 smoothies. It seems like I am only 2 or 3 mph faster then when on 31" BWs? Amazing part is that it takes off shorter and climbs much better on the smaller tires.
  1. wing twist
    By capav8 in forum Experimental Cubs
    Last Post: 02-20-2010, 05:19 AM
  2. Wing twist
    By PA-22/20-160 in forum Cafe Supercub
    Last Post: 10-15-2006, 07:07 PM
  3. Is there a twist in fuselage?
    By louie in forum Modifications
    Last Post: 02-09-2003, 02:07 AM
