Results 1 to 7 of 7
Thread: Question concerning G3X data.
    Jun 2016
    54
    In the G3X screen display that provides engine information there is data titled PERCENTAGE OF POWER. Found between the MP and RMPs.
    Is that the percentage of available power adjusted for DA or the rated power at sea level being used/available?
    Shep
    4,089
    Page 34-133 in the install manual says the percentage of power requires MP, RPM, and fuel flow inputs. To me the implication is that it's a true reading that compensates for DA.
    4,089
    Jun 2016
    54
    Stewartb – thanks for the reply. I read the same. However, ……….
    The problem with this is you have no base line for what 100%is.
    At sea level one would believe 100% of a rate 200 hp engineis 200 hp turning the correct RPM. ApplyDA and 100% is no longer 200 hp. It’ssomething less.
    So without going into some type of adjusted table what is 75%(HP) if DA if applied to the displayed information.
    Or perhaps 100% is 100% if you can make the RPMs. Obviously I am not an engine guy.
    BTW - the Garmin callcenter tech could not answer.
    4,089
    I assume 100% power is rated at 2700 rpm on a standard day. I think that's what they allude to in the last line of the paragraph. It's a good question.
    9,890
    it knows what altitude it's at... i'm sure it takes it into consideration.... "....as it is assumed to produce maximum power at sea level pressure..."
    they just hit the
    big spots in the manual, i'm thinking.... and even just hitting the high spots makes for 877 page install manual!!
    4,089
    That manual will cure insomnia faster than Ambien!
    Likes OLDCROWE, mike mcs repair liked this post
  1. Data tag
    By benflyn in forum Cafe Supercub
    Last Post: 10-08-2013, 02:15 PM
  2. FAA Data Base
    By Moose Turner in forum Cafe Supercub
    Last Post: 12-24-2010, 07:31 PM
  3. Data Tag
    By cubdriver55 in forum Cafe Supercub
    Last Post: 08-17-2010, 10:43 AM
  4. Data Plate
    By SC#1 in forum Cafe Supercub
    Last Post: 03-15-2006, 02:12 PM
