skywagon8a
SE Mass MA6
I recently found this Airmaster electrically operated and governed constant speed prop.
https://www.airmasterpropellers.com/
It uses whirlwind propeller blades on which the pitch is controlled by an electric motor. The controller can operate the blade angle manually or can function as a constant speed.
Recently there has been much discussion of using the Whirlwind light weight ground adjustable prop. This seems like a very nice upgrade by being able to control the blade angle in flight. The big advantage is that you don't need to cut a hole in the firewall for a governor and your engine doesn't need to be set up to operate a constant speed prop.
