Page 3 of 3 FirstFirst 123
Results 81 to 83 of 83
Thread: Experimental Shock Options and Reviews
  1. #81
    Bill Rusk's Avatar
    5,119
    Folks
    Larry Vetterman asked me to share a few photos and ideas for your consideration.......
    This is his second Javron Cub and he is getting close to completion.
    After a long winter away I’m getting back in the groove. Fuselage is now at the airport. One wing is in the paint booth. Then the other wing will get cover and primer and paint. Then it all goes together.
    Here is a $95.00 Tempress deluxe boat seat that Clint found and is using so I figured I would try it. Very comfortable, made in the USA. I installed one in my white cub and tested it before I committed to use them in my new one.
    Bill, I have no idea how to post pictures etc on SC.org, so feel free to pass this information along, as well as the first pictures I sent.
    Here is a simple set of form blocks I made to make the end ribs on the covers. They are made from 6061T6 by .035 thick. The big cover is .025 2024T3. The top rib is screwed onto the shock frame and the bottom one floats on the shaft via a 1/4 inch uhmw block. Simple to make and maintain. Larry v.
    Larry says.....I hope this helps.....
    Very Blessed.
    Thanks Oliver, tedwaltman1 thanked for this post
    Likes CharlieN, courierguy liked this post
  2. #82
    nd
    3,087
    looking at that seat makes me want to sit in it, looks good.
  3. #83
    Mar 2016
    Vermont USA
    615
    There are a few boat seats that are not bad weight wise while utilizing firm enough foam so one does not bottom out. I like that.
  1. Experimental nose bowl options?
    By KelvinG in forum Experimental Cubs
    Last Post: 02-11-2018, 05:22 PM
  2. SHOCK RINGS selection for PA18 experimental
    By jse18 in forum Super Cub Sick Bay
    Last Post: 03-03-2016, 12:12 AM
  3. Experimental PA-11 engine Options
    By Leniuk in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 05-21-2009, 07:54 AM
  4. Headset Reviews
    By supercub in forum Tips and Tricks
    Last Post: 09-17-2004, 11:01 AM
