Results 1 to 6 of 6
Thread: Sorensen tank with float fittings
    DJ's Avatar
    Jan 2009
    Bolivia
    154
    Has anyone installed a Sorensen tank on a Cub with float fittings? From looking at pictures it seems that there would be an iterference issue. The Sorensen tanks appear to be as wide as the longerons with no cutouts for float fittings.
    8,467
    I have done the reverse with bolt on fittings. There is interference.
    DJ's Avatar
    Jan 2009
    Bolivia
    154
    How hard was it to clearance the tank around the fittings? Hack saw and some fiberglass work?
    8,467
    I took the tank off. Yes cut & glass. Use float fittings for tank straps.
    Sep 2014
    Palmer Ak
    21
    Check out the Landes tank, they have cut outs for the flying wires. If it was me I would go with the Landes for floats and save the Sorensen for wheels. Do you have the 60 or 90 gallon tank?
    DJ's Avatar
    Jan 2009
    Bolivia
    154
    I'm on wheels. Just happened to have float fittings. Landes tank is $$$$
  1. Strange Fuel Tank Fittings
    By coxcub in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 09-20-2014, 09:20 PM
  2. My new float fittings don't fit
    By Tango Cub in forum Tips and Tricks
    Last Post: 02-28-2012, 07:51 AM
  3. Float Fittings
    By Roger Peterson in forum Modifications
    Last Post: 10-19-2005, 01:05 PM
  4. Float Fittings
    By Laz in forum Experimental Cubs
    Last Post: 04-19-2005, 12:04 AM
