supercub
Let me check my GPS, gee how'd we ever navigate w
I'm going to be installing an under seat battery, no alternator/generator in my PA-11, I'm planning on using 4 gauge wire from the battery to the master solenoid and 4 gauge from there to the stater solenoid and 4 gauge up to the starter itself. Does that sound correct?
What gauge wire should I use from the solenoids to the battery switch
What gauge wire should I use from the starter solenoid to the starter switch?
I'll be installing nav lights, just in case I get caught out after sunset, not planning on night flights, what wire size is recommended for those?
I'll also be running a portable or small comm radio.
What wire size should I run from the master solenoid to my small bus to power the above?
