Can you legally?
D dgapilot FRIEND Jan 29, 2019 #2 Eddie Foy said: Can you legally? Click to expand... Sure, if you want to spend about $100k to get STCs for them. Sent from my iPhone using Tapatalk
CamTom12 Registered User Huntsville, AL Jan 29, 2019 #3 dgapilot said: Sure, if you want to spend about $100k to get STCs for them. Sent from my iPhone using Tapatalk Click to expand... Could a field approval be gotten more reasonably?
mike mcs repair Registered User chugiak AK Jan 29, 2019 #4 Hmmm..... it’s just an accessory. We got alternator’s field approved Sent from my iPhone using SuperCub.Org
CamTom12 Registered User Huntsville, AL Jan 29, 2019 #5 mike mcs repair said: Hmmm..... it’s just an accessory. We got alternator’s field approved Sent from my iPhone using SuperCub.Org Click to expand... Your FSDO is probably the most likely to be successful with.
S stewartb MEMBER … Jan 29, 2019 #6 I'd guess the snowball's chance in hell analogy applies here. Mags aren't an optional accessory.
mike mcs repair Registered User chugiak AK Jan 29, 2019 #7 stewartb said: ..Mags aren't an optional accessory. Click to expand... we got propellors field approved... but alas, they were "real"PMA parts from another plane different #of cylinders engine (6 cylinder prop on a 4 cylinder engine).... all it takes is someone(FAA) willing to stamp it....
skywagon8a MEMBER SE Mass MA6 Jan 30, 2019 #8 If the certified engine is mounted on an experimental amateur-built airplane---yes.
supercrow FRIEND Smith Pond near Millinocket, Me Jan 30, 2019 #9 skywagon8a said: If the certified engine is mounted on an experimental amateur-built airplane---yes. Click to expand... And doesn't the engine become experimental, at least for now?
