Results 1 to 22 of 22
Thread: Can hear aileron cable rubbing when cold in 185
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    I noticed when cold turning the ailerons left or right on the ground with the engine not running I can hear the a aileron cable rubbing in the left wing.
    It was in the low 30's the other day and rotating the wheel I could hear a cable rubbing on what sounded like the aluminum skin. When temp is up around 40's there is no audible rubbing.
    It was my understanding that when cold the cables will be somewhat looser due to the different coefficient of expansion between aluminum and steel. Wings shrink more than cables. Had my mechanic look at it yesterday when it was in the 40's. We opened opened a panel on the aft portion midway out beyond the strut attach point and he said it measured around 22. Said spec was 30 +- 10 which puts it in range. Told him I wanted to take it in the hanger and have him take a good look.
    Can anyone shes a little light in whats going on?
    Tom
    Jan 2016
    41
    Very long shot possibility. IF............you have an autopilot..........and if it attaches to aileron cable............that could be the noise you hear as the attachment point moves around????
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    Pete,
    Thank you for the reply. I do have an A/P but it was installed last month and uses pushrods but this had been going on for quite some time now.
    Thanks Pete Schoeninger thanked for this post
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    402
    Had same thing happen on my cub the first winter i had it. Noticed an aileron cable scraping noise. Looked up in there with a mirror and a flashlight and found someone went on the wrong side of one of the rib cross braces with the cable. Never notice it until winter also.
    "There are 3 kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves." Will Rogers
    10,164
    Yes, Id check entire aileron cable run in that wing.
    Likes FdxLou liked this post
    9,889
    Lower rear door post is a common rub spot with fuel line. Sound may be in different area
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    The noise is definitely coming from the left wing about mid section, I am guessing.
    4,089
    A #2 phillips screwdriver and a flashlight will solve the mystery.
    Thanks RaisedByWolves thanked for this post
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    Its going in the heated hanger today so the mech can take a good look at it.
    8,896
    One thought since it is a 'below freezing' phenomenon, could you have a pulley that won't turn when cold, causing the chafe? If nothing else, that would be something to look for.
    Likes eskimo77, TCE, mike mcs repair, StuBob liked this post
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    Just finished the annual and every pulley was tested for rotation and lubed. I don't think cable tension was checked however.
    9,889
    there is a phenolic rub block about mid wing..... also seen cables fray there..
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    Bit of a delay and going in Monday to have a look see.
    8,896
    Quote Originally Posted by Tom3holer View Post
    Bet the annual was done above freezing. Things can get missed.
    8,586
    Tom
    Better look before it gets heated up. The rubbing may go away by itself when the plane is warmed up. Your tension was 22 with a tolerance of 20 - 40. Sounds loose to me.
    Nov 2017
    Vermont
    12
    Tom, I was re-rigging last few days and recall the book says aileron carry through cable tension is 40#.
    The Trio aileron servo is attached by a rod to the RH bellcrank. Were there any changes during the install?
    May 2006
    307
    I had to chase down a rubbing cable in the fuselage of a C172. Several of us looked all over for a rub and couldn't find it. Turned out to be a servo capstan rubbing against a cable retainer post.
    We were amazed at how a smooth capstan, running agains a smooth post converted into a rough 'cable rubbing noise'.
    Don
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    Yes the Trio uses a pushrod but there were no cable adjustments made. The noise I have noticed for some time long before the A/P installation.
    Mudwagon, Thank you for the heads up, the carry through tension as I see is 40 +-10 so 22 is certainly on the loose side.
    Thanks Gordon Misch thanked for this post
    FdxLou's Avatar
    Apr 2004
    1,722
    If I recall correctly, the only valid tension measurement is on the aileron carry thru cable. Not on either direct cable.
    Lou
    9,889
    Quote Originally Posted by FdxLou View Post
    Lou
    I liked this.. but probably not a valid thing... it's a LOOP...
    Tom3holer's Avatar
    May 2012
    Cape Cod
    437
    Lou,
    Yes I read that somewhere also and it should be measured in the overhead cabin area.
    4,089
    Do you hear this noise when pushing the ailerons through their range at the wing? Change directions quickly and you may hear the cable slap a little? Sounds normal to me.
  1. Aileron Cable - is this Okay?
    By SchulerJL in forum Super Cub Sick Bay
    Last Post: 04-15-2015, 07:14 PM
  2. Replies: 10
    Last Post: 12-07-2005, 02:55 PM
  3. Trim cable rubbing on extended bagage compartment
    By palhal in forum Modifications
    Last Post: 03-10-2004, 09:49 PM
