Thanks Thanks:  0
Results 1 to 14 of 14
Thread: PA 18-95 Super Cub B&C Alternator Paperwork Question....
    Apr 2018
    47
    Hello, Is there anyone out there that has gotton a one time Field Approval for the installation of the B&C 30A P/N BC-433-H Alternator on the C90-12F? If so, I would like to use your prior authorized Field Approval paperwork for doing the same on mine. I have done this on other installations....If its been done before this counts as "Approved Data" and would prove as grounds for me to do this through my FSDO. Thanks.
    1,114
    I have a 13A B&C 200G approved on a C-85-12F. Have you considered a PlanePower 50A STC'd unit?
    https://planepower.aero/product/airc...r-conversions/
    https://planepower.aero/wp-content/u...11-0000-PP.pdf
    Apr 2018
    47
    Plane Power
    Im going to have to check on that too! Thanks.
    Gary, It would have to be someone that installed it on the same model engine.
    1,114
    I think the C85-12F and C90-12F share accessory case and gear parts. Same old generators. See link.
    The PlanePower is STC'd for a C90-12F per the 2nd link above.
    Attached Files Attached Files
    Apr 2018
    47
    Same ....
    Gary, they may share the same acc case cover but in the eyes of tg he FAA in order to use is as acceptable approved data to base my field approval off i think the engine data tags will have to be the same model.....
    1,114
    Ok. How about this STC?
    Apr 2018
    47
    I couldnt make out the first page. Doesnt look like the AML lists the PA-18. The last page sounds promising but the STC is talking about a 30 amp generator?????....Not alternator......?
    Apr 2018
    47
    Apr 2018
    47
    I'll try this PDF again for STC SA02283AK
    You dont need to....standby....i found it on the FAA site
    Apr 2018
    47
    Well thats the same part number and everything.....i think we may have a winner! I may contact them tmrw.....the CAR3 info on the last page seems to be KEY here.....thank you!
    1,114
    Here's an amended comment to the STC PDF
    STC- FAA APPROVALS for AIRCRAFT NOT ON THE FAA AML listing or otherwise
    MODIFIED by FAA APPROVED ENGINE CHANGES
    Installation of the Lightweight alternator in vintage aircraft is APPROVED for aircraft OTHER
    THAN those listed on the FAA AML by specific language in the STC SA02283AK cover sheet:
    How that works:
    STC certification is obtained to a set of standards related to the STC application. An approved
    model list is then issued by the FAA which designates those KNOWN type certificated airplanes
    for which the STC is an applicable installation.
    In the case of many older airplanes, engines like the A-65 or C-75 Continental have been
    replaced with upgraded versions like the C-75-12, C-85-12, C-90-12 or -14, O-200, the O-300,
    or the GO-300. Each of those improved engines can be FAA approved for installation on
    certain airframes by either FAA field approvals, FAA STCs, or FAA approved service letters
    that modify the type design criteria- any of which can be cited by the mechanic as “FAA
    APPROVED DATA” substantiating the change on an FAA form 337.
    It is not possible to list on the FAA approved STC AML, a comprehensive listing ALL of those
    potential combinations, since many are one-off change approvals, or otherwise obscure FAA
    approved data that is not readily available to the FAA engineering personnel or the STC
    holder/applicant.
    Since MANY older airplanes have been modified with engine changes, where the installed
    engine CAN NOW ACCOMMODATE AN ALTERNATOR, because the engine has a suitable
    generator drive pad drive, the FAA has addressed such changes with a general approval in the
    limitations and conditions of the STC itself. The Alternator STC SA02283AK has such a
    condition and FAA approval at paragraph 5 of the cover sheet.
    It states:
    5) This installation approval is limited to aircraft models equipped with
    a Continental C-75-12, -12F, -12FJ; C-85-12, -12F, -12FJ, -14F; C-90
    -12, -14F; C-145-2, -2H; O200-A, -B, -C, O300-A, -B, -C, or GO-300-
    A, -B, -C, -D, -E engine in accordance with FAA approved data.
    This set of FAA ‘open approval’ instructions in the STC were developed with the FAA’s full
    understanding and knowledge that such vintage airplanes often swapped engines for
    performance and availability reasons.
    This FAA APPROVAL CONDITION was intentionally added to address the inherently
    restrictive nature of an AML, and to provide greater options to the end users and operators who
    wish to incorporate a modern, lightweight electrical generating system into their vintage airplane
    which has already adopted other upgrades or safety enhancements.
    The installation of electrical busses, and other wiring in the airplane may of course be approved
    pursuant to original factory TC data, by FAA field approvals, or simply by a reference to the
    acceptable data in sections and paragraphs within AC43.13-1B & 2A, on the FAA form 337
    Apr 2018
    47
    Are u interpreting this the same way i am?
    1,114
    Yes but I'd contact the STC holder/vendor first and obtain guidance on how to navigate the approval for your application: CLASSIC AERO @ 480-650-0883
    Read all of their STC info: http://luscombe.org/tips%20and%20stc
    The Power Plane unit may be simpler: https://planepower.aero/wp-content/u...11-0000-PP.pdf
    Apr 2018
    47
    Gary, My thoughts exactly. Thanks!
  1. Paperwork question...ARROW
    By mghallen in forum Super Cub Sick Bay
    Last Post: 03-17-2012, 05:31 PM
  2. PA-12 Alternator STC/PA-18 alternator question
    By glassjet in forum Experimental Cubs
    Last Post: 12-27-2005, 01:39 PM
