Results 1 to 15 of 15
Thread: Belly Pod
    Feb 2009
    67.8N,115.1W CYCO Canada
    762
    Belly Pod
    Does a belly pod create any problems with "ground clearance" when on skis?
    Is there room for tent, tent fly, tent poles, two mattress pads, sleeping bag, wing and engine covers and two small backpacks - one with survival items and one with food?
    Can a belly pod be used when on floats? (Not that I really need the extra space since I have big compartments and carry less stuff during the summer).
    spinner2's Avatar
    Montana
    1,692
    I think it would depend on your skis. My big Carbon Concept skis are buried here but the pod stayed above the snow. The gear is 3" extended and the pedestals put the axle nearly as high as it is on 31's.
    Thanks NunavutPA-12 thanked for this post
    1,437
    If the snow is deep enough it just acts like another ski. Standard pod can carry a lot when properly packed, when you say tent and mattress pads, how big are you talking? Experimental guys can get the extra deep pod.
    9,660
    yes on floats... you will need to drill holes for rear wires, and cut for rear float fittings... but doable... maybe not pretty..
    10,058
    Um, not necessarily. My experience with that on a Cessna 185 with a much more streamlined pod than some Cub pods was that it created HUGE drag if it got in snow.....and if it was deep, it got in the snow. I did a lot of snowshoe prepping takeoffs that winter.
    A Cub on big skis, being a much lighter airplane, is a lot less likely to get into this situation, but I've been in snow conditions with a Cub that I really, really wouldn't have wanted a pod on the plane. Like four foot deep powder.....
    Likes DENNY, BC12D-4-85, NunavutPA-12 liked this post
    C130jake's Avatar
    Sep 2012
    Minnesota
    353
    Quote Originally Posted by NunavutPA-12 View Post
    Extra work for the float swap.Click image for larger version.
ID:	40818Click image for larger version.
    Sent from my SM-G930V using SuperCub.Org mobile app
    aktango58's Avatar
    18AA
    8,844
    Quote Originally Posted by C130jake View Post
    After the first goat rope I began leaving my fly wire ends on the upper aft fittings so I did not have to spend an hour putting cotter pins in every year!
    I could carry my Arctic Oven and two cots in the pod. Might get wing cover in but not engine cover, (18 combo pod).
    The nice thing about a pod is carrying stuff you don't want to warm up, thaw and freeze again, like covers.
    I never had an issue with deep snow when I ran the pod. Worth having.
    Apr 2018
    26
ID:	40826Click image for larger version.
ID:	40827Click image for larger version.
ID:	40829Click image for larger version.
    Depending on the pod, you probably will have to reroute the wire for the rudder lift. On mine, the wire was attached to the both end wire from the rudder at about over the rear spreader bar so I’ve made a bracket with a pulley attached to the left rigging strut. That way, it pull a little bit much more on the left rudder than the right.
    I don’t know if I’m the only one to have experienced this with a belly pod on floats but I’m no more able to turn when the floats are “plow”. Before having the pod installed, I could begin to turn, lift the rudders, full power and continue to full turn until I got on the step, usefull on small lake . Now, when I put full power, even if I press full rudder one side or the other, it only goes straight. Am I the only one to live that?
ID:	40831Click image for larger version.
ID:	40832Click image for larger version.
ID:	40833Click image for larger version.
    And for the content, here’s the measurements
    25” wide in front
    14” depth at the deepest
    82” long
    And about 8-10” depth at the rear end
    Apr 2018
    26
    Oh! I forgot... I’m sorry if I’ve made some mistakes, English is not my primary language, I usually speak in French.🤷*♂️
    AK
    3,876
    I'd be in the remove pod for floats camp. Easy.
    Alaska Bush Pods are great for adding capacity right where you'd like the CG to be and don't have many down sides even when you fly with it empty.
    Apr 2018
    26
    Does Bob Piatt still makes pod?
    Thanks jrussl thanked for this post
    Likes jrussl liked this post
    jrussl's Avatar
    Jul 2005
    Madison, WI
    454
    Quote Originally Posted by bush4 View Post
    Yes he does. Great pods. Landed at his place in July and bolted this one on. One of the best additions to my SuperCubClick image for larger version.
    Apr 2018
    26
    Quote Originally Posted by jrussl View Post
    I really love mine too, it’s huge and lightweight. But On floats, harder to access to your stuff within 🤪 the strut and the flying wires do not help
    Likes jrussl, mike mcs repair liked this post
    aktango58's Avatar
    18AA
    8,844
    I really love mine too, it’s huge and lightweight. But On floats, harder to access to your stuff within 浪 the strut and the flying wires do not help
    That is correct, there are downsides with floats- but still easier than the Atlee extended baggage
    I had the Airglass Combo pod, so door was smaller than the Bush pod. Bush Pod, or Randy's carbon one, are much bigger. Randy has a door in back, so for floats that might be the ticket also.
    For the pull up system, I had a loop from one rudder to the other with an eye set where it pulled each rudder evenly. I used a small braided parachute type chord from my pull up handle down to the eye in the cable loop. I ran a piece of stainless or aluminum around a spreader bar and mounted a pulley to it inline with where the cabin line came out; line went from the eye, through the pulley and into the cabin with no chaffing of the pod. Took about an hour to fab up. Was also cheap and easy to take apart and replace every two or three years when it might need it.
    Apr 2018
    26
    On floats, you can forget the pod’s back door, too hard to access (for me)
    Do you experience the same issue, turning while the the floats are “plow” is impossible, it goes straight until you’re not on the step?
  1. Belly Cam
    By Henny in forum Video Vault
    Last Post: 12-11-2012, 12:51 AM
  2. Belly Pod for PA-12
    By Seaworthy in forum Products, Purchases, Reviews & Prices
    Last Post: 08-03-2010, 12:36 AM
  3. To Belly bod or not to Belly pod, that is the question
    By Fortysix12 in forum Cafe Supercub
    Last Post: 10-19-2006, 05:43 PM
