Page 3 of 3 FirstFirst 123
Results 81 to 92 of 92
Thread: Fairbanks FAA Seminar Concerning Destroyed Aircraft
  1. #81
    2,439
    The registration expires if not renewed every 3 years.
    FAA then "de-registers" the airplane.
    This seems to be the major cause of de-registered airplanes.
    Sometimes due to carelessness, sometimes due to the airplane being wrecked and then who cares.
    Tail number is then put on hold for 5 years,
    I assume to allow the owner to re-register it if he pulls his head out of you-know-where
    and realizes that he allowed registration to lapse.
    After that 5 years, the tail number is up for grabs.
    I never thought about the airworthiness aspect of this.
    My thought would be that the registration & the A/W certificate are two separate issues,
    but from the previous post I guess the FAA doesn't agree.
  2. #82
    May 2017
    339
    The problem many of us are finding is when the registration isn’t renewed, or is otherwise canceled, FAA assumes the aircraft was scrapped or destroyed, and then it is a royal pain to get the registration back. In several cases I’ve been involved with, they want the TC holder to confirm that the dataplate is the original one issued, even if the current TC holder isn’t the same organization that built the aircraft. This is just ridicules!
  3. #83
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,369
    Quote Originally Posted by Hardtailjohn View Post
    The way I see it, I have a Super Cub project that needs new fuselage and wings... 35+ years ago, this wasn't really worth rebuilding, so the registration and all was let expire. I've gone through all the steps and it now has current registration....but it's history says it was scrapped or lapsed in the past. Now it's well worth rebuilding, but it's going to have to go through an inspector, who chances are, has never seen a PA18 naked, and it's his/her choice to make a decision whether I get to rebuild MY airplane? At the least, this is going to cause me to build an inferior aircraft because it sounds like a huge PIA to replace both at the same time, like I had planned. We're allowed to replace ANY part with a PMA'd or STC'd part, but just not all at one time. What a crock!
    So ...... replace fuselage, logbook shows aircraft returned to service. Two months later, wings damaged and replaced, returned to service. If IA is doing this it's legal, right? Does the FAA actually have to witness a flight when "returned to service"? Catch my drift? If a rebuild takes you a year, maybe you did it in three stages, returned to service for two months between each step. You just flew it at night and no one saw it in the air ..... guess it would work if airworthiness cert never expired.
    Marty
    N367PS
    www.marty2plus2.com
  4. #84
    8,827
    Well, it seems that the FAA has again moved the goal post. It is up to us as a group to find the loop hole with the work around. Collectively I'm sure that we can achieve the upper hand.
  5. #85
    Mar 2016
    Reno, NV
    64
    Experimental?
    Quote Originally Posted by Mark_Moyle View Post
    I didn’t make it to the meeting. Did speak with a guy who did attend. He came away with the idea that the new regulations were designed to eliminate liability for the manufacturer of the aircraft and that it is to promote sales of new aircraft to replace older aircraft. His opinion was that the FAA is attempting to reduce risk of shoddy workmanship, saying that after rebuilding a totaled aircraft it can’t be brought back to the same standard met by the manufacturer and that it can’t be re-certified. That it can be moved into the experimental category. So...I asked. If I own a $25,000 certified aircraft and only insure the hull for $25k and it gets totaled by the insurance company because it’ll cost more to repair due to the insured Hull value? That I can’t rebuild it and keep it certified if the damage costs more than $25k? But if I insured that $25k aircraft for $50k and the repair cost is less than that it can be repaired as a certified aircraft.
    So after talking with him....I read the regulation... doesn’t lead me to believe my restoration after the insurance company totaled is effected by this regulation. Didn’t see anything about taking a certified aircraft into the experimental category.
    Sent from my iPad using Tapatalk Pro
    What? What category, amateur built, exhibition, research?? I thought this was exactly what the FAA did not want to happen.
  6. #86
    May 2017
    339
    There are no new “regulations”, only policy in the form of Order 8100.19. The problem I see is that FAA is determining aircraft to be destroyed or scrapped where there was no accident, and no parts were sold as salvage, just that the owner didn’t renew the registration. Registration should have nothing to do with airworthiness, other than being a prerequisite to legally operating an aircraft.
  7. #87
    Mar 2016
    Reno, NV
    64
    Yes I'm finding this out with the Pacer project I posted about on the other site. Reg denied twice. First time because previous owner checked destroyed. It wasn't wrecked at all, just had a runout motor and 35 year old fabric. He sold it to a guy who wanted the wings for a different project. That guy got sick and passed so I bought the Pacer. FAA reg wanted pics of everything including logs to prove it was not destroyed, I sent them that, denied second time because aircraft was in pieces. Well yes the wings and tail are off, so I'm debating what now? Continue down this path and put it together and certainly face further denials and hassles? How much $$ should you put into a plane with no paper work?
    I think everyone can see they want these aircraft off the books for good and will make it increasingly difficult to legally repair/restore them.
    Thanks Airhutch, mike mcs repair thanked for this post
  8. #88
    May 2017
    339
    At some point it will take a class action suit against FAA to fix it. This all got started back in 2010 when registrations expired.
  9. #89
    Jul 2010
    Elizabeth, WV
    488
    Sometimes we create the problem. Case 1, C170 cartwheeled on takeoff. Owner Flubb sold the wreck to 170 Expert who took 4 years repairing the airframe and engine but ignored the paperwork. After 3 1/2 years Flubb happened to look up his old airplane on the web and found it still registered to him. Fearing something wonky was going on and he might get dragged into a lawsuit, he wrote the FAA a letter and deregistered the aircraft as destroyed. If Flubb would have filled out the back of the registration and mailed it in like he was supposed to when he sold the plane or if the Expert would have taken care of the registration when he bought it there wouldn't have been a problem. Case 2, Freezerburn sold his experimental to Gotrocks who kept it in his garage for two years and didn't register it. Why he would have had to pay a few dollars personal property tax to his home state if he registered it. And he lost the bill of sale. But the chance came to make a few dollars so he sold it to Cheapo who put it in his garage for two more years. He didn't want to pay Personal Property tax either. In the meantime Freezerburn passed away so there won't be another bill of sale unless it's forged in a dead man's name. Now Cheapo wants to drag this thing out, get a condition inspection, pay his taxes, and fly. Cheap bastard, I'm not gonna help fix this mess. I got better things to do.
  10. #90
    6,482
    That's funny! I think I agree with you!
    Still, there ought to be some enlightenment back at 800 Independence. Those guys need to come fly Cubs and slow down a bit on the ACs and Orders.
  11. #91
    May 2017
    339
    Quote Originally Posted by N86250 View Post
    And that was the way aircraft transactions took place prior to 2010. Since the time limit on registrations was put in place, they’ve come up with all these new policies that don’t make a lot of sense.
  12. #92
    wireweinie's Avatar
    Palmer, AK
    2,243
    Quote Originally Posted by dgapilot View Post
    How about a class action suite to force them to abide by the FAR's.
  1. The Almost Annual Supercub Seminar, Fairbanks Jan 24!
    By tamarack in forum Cafe Supercub
    Last Post: 01-29-2015, 03:40 AM
  2. Fairbanks Supercub Seminar 2/23
    Last Post: 02-25-2013, 10:20 AM
