Your oil control rings are worn out pumping oil into the combustion chamber where it is being mostly burned.
Wash down the engine to remove all of the wet oil from the outside. Then fly it once around the traffic pattern and look for the oil leak. If you fly it too much the oil will spread around making it difficult to find the leak/s.
Would a decent ground run (with the cowls on or off?) also be enough to generate the leaks? AND without the 80mph plus slipstream to spread the oil around?
