Results 1 to 13 of 13
Thread: The welding is done- I think !
    Apr 2014
    Manitoba Canada
    158
    So I have a dilemma and am looking or someoneís 2cents.
    It is now time to sandblast my airframe. The shop that Iím going to use is about 15 miles from my garage and is not heated. Once it is cleaned it will be transported back home and be epoxy primed. I am not going to be able to paint it the day it gets back home from being blasted. How worried should I be on flash rusting? What can I do to minimize it or should I not worry??
    Likes WanaBNACub liked this post
    18,285
    Can you heat your garage until you can prime it? There are products you can spray on with a pump up sprayer to keep it from flash rusting.
    Eddie Foy's Avatar
    Dec 2014
    3,249
    https://www.theruststore.com/Picklex...4aAk6BEALw_wcB
    Quote Originally Posted by Beaverpilot View Post
    So I have a dilemma and am looking or someone’s 2cents.
    It is now time to sandblast my airframe. The shop that I’m going to use is about 15 miles from my garage and is not heated. Once it is cleaned it will be transported back home and be epoxy primed. I am not going to be able to paint it the day it gets back home from being blasted. How worried should I be on flash rusting? What can I do to minimize it or should I not worry??
    Apr 2014
    Manitoba Canada
    158
    my shop has heat and the weather here now is cold and dry
    Stew's Avatar
    Jul 2013
    Haywards Heath, UK
    109
    Soda Blasting
    It is my understanding that if you have it dry "Sodablasted" then you have a fair amount of time between completion of the blast process and application of the two pack.
    The soda bicarbonate is a natural rust inhibitor and does offer significant protection in the short to medium term and does not "pit" the surface like a more abrasive media. It will remove light rust but you will have to pressure wash the fuselage with plain water just before you start the painting process to remove the soda deposit. You can enhance this process by adding something like HoldTight 102 to the pressure washer which will deal with any salts, chlorides and contaminates on the metal.
    https://www.holdtight.com/
    Likes Beaverpilot, Hardtailjohn liked this post
    Eddie Foy's Avatar
    Dec 2014
    3,249
    If the humidity and temp are low, flash rusting is not a huge problem. Don't handle it with your bare hands.
    In South Florida--Fugedaboutit!
    Apr 2014
    Manitoba Canada
    158
    Thanks Eddie, my experimental pieces of tubing have been showing me this over the past week. Blasted and let sit outside in the bare metal touched a few spots with barehands and brought in to the heated shop. So far I found one little spot of rust and a scotch bright pad would definitely take care of that.
    Meanwhile,...
    4,908
    From my days as a Steel Structures Painting Council qualified inspector I say NO! But in practicality, I say it depends on the conditions and duration (don't wait a week) and as Eddie points out no bare hands is critical and then be very careful with the potential for condensation forming as you get cold steel in into a warm place so you can paint it and if that happens (say your glasses fog over when you carry it in) it is best to start over but be very careful of how deep of an anchor pattern you cut into the steel with the blasting as it can exceed the dry film thickness of the primer (not as bad with epoxy as they don't shrink much) and then you can get surface rusting on the peaks.
    One of the temp inhibitor coatings will likely buy some time but make sure it is compatible with the final coating and the type of steel.
    Any chance of finding a shop that will blast and prime for you, could be money well spent?
    OC
    Ps, remember it's not just the rust you can see that's the long term problem.
    Apr 2014
    Manitoba Canada
    158
    OC
    Iím looking at 48hours or less. I figure one day to blast the airframe and bring it home and the next to set up the spray booth and paint.
    Meanwhile,...
    4,908
    Sounds like you’re building a temp booth, if possible pre-build and leave the end open so you can push it in, seal it up and start the warm up. With luck you might get it done pretty quickly.
    Likes Beaverpilot, Nolan liked this post
    Apr 2014
    Manitoba Canada
    158
    That was the plan. Iím doing this all on my own. The blasting and painting. I have help moving, hauling and lifting the airframe.
    Cub junkie's Avatar
    My Moms basement
    2,025
    I have always been able to get to a fuselage right away after media blast but a friend of mine was in your shoes and supplied all the helpers with new cotton gloves to help him load and unload. I think he had some rusty palm prints on something one time so he wasn't taking any chances.
    Likes OLDCROWE, Beaverpilot liked this post
    phdigger123's Avatar
    Mar 2011
    Cottage Grove, Mn
    260
    While warming it up, have some fans blowing on it to reduce the chance of condensation.
    Likes OLDCROWE, Beaverpilot, Hardtailjohn liked this post
  1. TIG welding, WOW!!
    By meinster in forum Member Projects in Progress
    Last Post: 03-12-2014, 09:56 PM
  2. Mig welding
    By raspraker in forum Experimental Cubs
    Last Post: 04-29-2004, 06:14 AM
  3. Welding IFR
    By j3jm in forum Cafe Supercub
    Last Post: 12-16-2003, 08:40 AM
  4. gas welding
    By A BELLAND in forum Modifications
    Last Post: 01-17-2003, 08:24 PM
