Results 1 to 8 of 8
Thread: G3X Engine Information Settings
    Feb 2018
    68
    I was just curious if someone could pass along the G#X Engine Settings (green, yellow, and red arc's) for the following systems:
    CHT
    EGT
    OIL TEMP
    RPM
    MP
    VOLTAGE
    It is a Titan O-340
    I appreciate any help. Pictured attached, but blurry as crao!
    Chad
    Sorry for the dumb questions, I'm an FNG!
    10,031
    2,258
    All that info is manufacturer provided. TCDS or whatever they were built under.
    4,277
    There won’t be redline limits for EGT, MP, and voltage isn’t defined by the engine manufacturer.
    When I did mine the RPM input setting was frustrating. I set it per instructions and it was at 50% of actual. Eventually I sat in the plane and toggled through the different settings and found one that works but it isn’t per manual. Don’t drink a lot of coffee before you set it up. It requires some patience.
    Oh, and hope whoever pinned the system remembered to put in the jumper to terminate the Can Bus. That was more than a little frustrating and I’d still be stumped if it weren’t for Mike!
    Thanks aktango58 thanked for this post
    Sep 2013
    Southern Utah
    19
    Continental sent me this Engine Operating Limits for my O-340.
Name:	Engine Operations Limits.png
    Thanks SinCityJets thanked for this post
    Feb 2018
    68
    Exactly what I was looking for!
    Anyone know the temp ranges for carb temp sensor.
    4,277
    My old one was -10 to +10C as the yellow arc, so 14-50*F. Which, by the way, was where the needle sat about 100% of the time. Worthless instrument.
    4,277
    Why didn’t Legend set it up for you? I thought the airplane had already flown? Did you have an issue that set you back to square one? Are the ADHRS and Magnetometer already set up?
  1. PA-18A Flap Settings
    By SchulerJL in forum Cafe Supercub
    Last Post: 03-12-2018, 12:30 PM
  2. C90-12 power settings
    By garyh in forum Modifications
    Last Post: 08-20-2009, 03:51 PM
  3. Information needed - Exhoust gaskets for C-75/85 engine..,.
    By Clyde and Susan in forum Cafe Supercub
    Last Post: 05-29-2006, 09:13 PM
  4. TORQUE SETTINGS
    By CUB'N in forum Tips and Tricks
    Last Post: 04-15-2004, 06:48 AM
