Results 1 to 22 of 22
Thread: Cub Diet Costs
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    402
    Cub Diet Costs
    So here are some very very rough numbers
    I have put my cub on a diet and am extremely impressed with the results. But it does come at a cost.
    These $ numbers are Australian so for all you Americans - $1 US = 70c AUD - Ouch! We pay big time here for your parts. Plus 10% GST and then freight on top then the rip off of many middle men on the way. It doubles our cost.
    These are the cost per lb saved in Australian $
    Carbon fibre floor boards - 10 lb $120/lb
    Earthex battery - 12 lb $58/lb
    Magnesium flywheel - 2 lb $540/lb
    Dynamo type alternator - 5 lb $160/lb
    Whirlwind prop - 20 lb $200/lb
    Carbon fibre seat base and backs - 10 lb $30/lb
    Carbon fibre doors - 10 lb $60/lb
    Remove pod - 22 lb $0/lb
    Remove steps - 6 lb $0/lb
    Magnesium sump - 6 lb $300/lb
    New Javron wings - 84 lb $142/lb (sale of original Smith wings with extend fuel tanks 76 gallons total taken into account)
    LED lights - 6 lb $17/lb
    No value has been put on the many many hours manufacturing some of these parts.
    So far I think I have saved 190lbs - wings still have to be painted and fitted.
    These prices take into account the sale of some of the parts I took off. (Still have 84/44 Borer for sale so that is not included - anyone?)
    Halve these numbers for equivalent $US
    I put more value on each pound the further forward it sits. But I think the flywheel was a bit over the top.
    Please don't add it up for me as I don't want to know and I don't want "Her in Doors" to find out- but I am very happy with the results.
    Likes 40m, jasimmons, courierguy, flyrite, Bill Rusk and 3 others liked this post
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,594
    What kind of compression are you running? I ask because high compression and super light prop/flywheel combos have been known NOT to play well together.
    cgoldy's Avatar
    Apr 2009
    402
    Why is that? What happens?
    O-375 8.5 - 1
    tcraft128's Avatar
    May 2006
    St. Marys GA
    772
    Titanium flywheel? Where can I get one of those!
    Turning money into noise since 1996
    Our Build here
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,594
    High compression engines have more pronounced impuse cycles and generally require more dampening mass. At 8.5 I wouldn't be concerned, but as you get up around 9.5-10, the harmonics can get unhappy. More than one high comp. experimental engine has sent its prop into the ether, along with the crank flange.
    FWIW, when I rebuilt my -12 a few years ago, I also went on a major weight campaign - dollars be damned (well, pretty much). I didn't even TRY to make mathematical sense out of it, I knew better. Hell, I'm still trying to forget how much I spent!
    Dec 2004
    Inkom, Idaho
    1,126
    I replaced my traditional master switch when I also changed over to an EarthX battery. The old battery install was mounted under the passenger seat, along with the master. The new setup has the battery and a new mechanical master (Summit Racing) on the inside of the firewall. It was amazing the amount of misc. cabling, fittings, etc. this saved, plus I can now forget to kill the master and not have it drain my battery. A pretty much idiot proof master switch, finally!
    stewartb's Avatar
    Alaska
    3,769
    Quote Originally Posted by cgoldy View Post
    O-375 8.5 - 1
    I know lots of guys running high compression with light props. No prop separations that I've heard of. Start timing is important as light props can have starter kickback issues. I know about that one up close and personal.
    Does your spendy flywheel use a conventional ring gear?
    Lightweight props with moving parts are advised to be dynamically balanced. You may want to look at a Balance master balance ring.
    Tony flyrite's Avatar
    Mar 2013
    Lyons,GA
    235
    Titanium flywheel - 2 lb $540/lb
    Titanium sump - 6 lb $300/lb
    Awsome CGOLDY....Also one overlooked area that you can save some lbs is your battery box. If yours can be removed and you are already using the earthx. Buy their box. weights ounces and is good for over 10 G. Saved almost 5 lbs on my acro mount.
    FEAR IS A REACTION, COURAGE IS A DECISION
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    281
    Now for the Pilot!
    Doug
    cgoldy's Avatar
    Apr 2009
    402
    Quote Originally Posted by Colorguns View Post
    Now for the Pilot!
    Doug
    What are you inferring Doug!
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    281
    I guess it should have had a. ? At the end.
    I could loose 10-15# and that would be pretty inexpensive way to cut out some weight.
    Not or sure about anyone else. Just me n my bird.
    Doug
    Likes 68Papa, TurboBeaver liked this post
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    740
    190lb is a lot of weight ! Congratulation.
    Would like to have some info about : Carbon fibre seat base and backs - 10 lb $30/lb
    30$ per pound is in my budjet
    Quote Originally Posted by tcraft128 View Post
    I know that you know that he's talking about the magnesium flywheel
    Likes tcraft128 liked this post
    cgoldy's Avatar
    Apr 2009
    402
    Quote Originally Posted by Olibuilt View Post
    http://www.skydynamics.com/products/...eight-flywheel
    Your right, Magnesium, I better edit my post
    Seat backs/bases - I replaced the wood ones with 2 ply and honeycomb core CF I vacuumed bagged down onto a glass table. Also cut down my full width back seat into a single which also gave the passenger access to the under seat storage box either side of the seat. My seats are fancy leather with memory foam so they were very heavy.
    May 2014
    14
    I'd love to hear about your carbon fiber doors as well. Sounds awesome!
    Any pictures of the build process and installed?
    cgoldy's Avatar
    Apr 2009
    402
    Quote Originally Posted by motosix View Post
    Carbon fibre doors and windows
    Windows
    I cut out of 1" High density foam sheet a 1" wide door frame. Laid it on a sheet of glass and vacuumed baged it with a flange on the outer perimeter to seal the airflow and inner periimiter to fix the window to. Then glued in the window.
    Doors,
    From the same 1" HD foam I cut out the shape of the door and wrapped it in CF and again vacuumed bagged it to the glass. I wanted a window in it but I was over the whole job by then and just wanted to get on with it. So it is solid, but stiff light and strong. I routed out a chanel on the inside and replicated the door opening mechanism out of CF rods. CF hunting arrows were used as the door latch rods. Then pop riveted a cover over the access hole I had created.
    It took weeks!
    No photos but I will take some
    Likes mike mcs repair, Gordon Misch liked this post
    May 2014
    14
    Windows
    Doors,
    It took weeks!
    Oh, my. That sounds awesome!
    Photos please!!!!
    cgoldy's Avatar
    Apr 2009
    402
    She flies. Still have new CF lower cowl to make with square airbox. Haven't weighed her yet but will do and post that along with new stall and cruise speed numbers. Busy moving the farm. But she leaps of the ground like you wouldn't believe. I put the pod back on for the ferry flight to new place.DSC_7326-1.jpg
    Likes mike mcs repair, Olibuilt liked this post
    Bill Rusk's Avatar
    4,873
    Fantastic!!!
    Congratulations. Light weight costs. And I think its an exponential curve.
    Very well done.
    Very Blessed.
    Nov 2003
    Thun Field, Washington
    747
    I think you mean expendential.
    Bill Rusk's Avatar
    4,873
    LOL Good one.
    Very Blessed.
    17,818
    From all my weights I am seeing a 2.6 lb savings using carbon fiber floorboards over the original plywood.
    cgoldy's Avatar
    Apr 2009
    402
    I can't check now. But it included extended baggage. My CF was basic rule of thumb 1/3 steel , 1/2 wood, 2/3 aluminium. Pretty rough figures though. I'm no Bill Rusk!
  1. Replies: 102
    Last Post: 12-16-2017, 01:37 AM
  2. Super cub diet - I must be crazy!!!
    By cgoldy in forum Experimental Cubs
    Last Post: 07-05-2013, 12:30 AM
  3. Cub on a diet
    By mongo in forum Experimental Cubs
    Last Post: 07-24-2011, 11:40 AM
  4. Got her on a diet again
    By OLDCROWE in forum Modifications
    Last Post: 03-15-2009, 03:09 AM
