supercub
Let me check my GPS, gee how'd we ever navigate w
What are your thoughts on installing a tube running from the lower motor mount (firewall corner) on the fuselage up to the cluster where the corner of the instrument panel is located. It would criss cross the existing tube that runs from the upper motor mount down to the cluster where the front gear attach is. The tubes would not touch. I'm no engineer, but just appears the added tube would add some strength to the motor mount/ firewall area. Your thoughts? I'm rebuilding a J-3 Cub and was wondering about this.
