Results 1 to 17 of 17
Thread: Engine for Javron Cub
    Oct 2013
    34
    Hi Folks,
    Yesterday was a big moment to witness the test run of my Titan 0-370 at Jay’s shop in Brainerd. Nothing like standing in the prop blast and smelling the exhaust of the first run. Something primal about that! She ran flawlessly. Jay made adjustments to the oil pressure and idle rpm. It was so cold outside that we had to wrap the oil cooler with foam to get the oil temp up to 180.
    This engine has 2 Pmags, magnesium sump, lightweight starter and alternator, which is pad mounted on rear case. I will be running the Whirlwind ground adjustable GA-200L-80. Since I am using Jay’s lowered conical engine mount, I will need to use a custom exhaust to have sufficient clearance. Jay is working on this design and should be available shortly. If you want to consider having Jay build up an engine, best to contact him now as he has a few on deck.
    A couple of pictures included.
    Wendel
    F1BA7460-C372-4227-B93A-27AD2BBE3E8A.jpeg2708781D-5BAC-4C0E-A8A5-80C65D56C06E.jpeg2817AC3D-B544-484A-A372-254C1C076CBA.jpeg
    nd
    2,831
    when you take a motor over there to run it, did you have it in the final ready to run condition, or is it ok to put the mags, carb, prop, etc. on over there? engine mount?
    Oct 2013
    34
    Jay built the motor and installed the accessories, so for a test run we installed the baffle, prop, and hooked up connections for oil, pressure, temps, etc. I don’t know if Jay would be willing to run an engine on his test stand that he did not build, but no harm in asking him.
    1,812
    Pics of the accessory case with the alternator?
    Jul 2013
    Brazil
    30
    Is this your Jay’s lowered conical engine mount, those with zero trustline?
    Oct 2013
    34
    Will post pics when I receive the engine with all accessories mounted
    Oct 2013
    34
    This is Jay’s lower engine mount with zero thrust line
    8,680
    Congratulations! One more step forward and closer to flight!
    17,616
    Jay told me most of the kits he sells have the zero thrustline engine mount. Curious how many are the lowered mount and what that does to the prop clearance. Too bad he doesn't keep his word with Thrustline Mark.
    Likes FdxLou, mike mcs repair liked this post
    3,531
    Just wait. Feeling that engine rattle to life in front of you is even better.
    Sep 2004
    Illinois & Wisconsin
    552
    How much does that engine weigh with the everything except the propeller?What is the ballpark price for an engine built by him?Any idea what an O-320 built light would weigh and cost?
    Oct 2013
    34
    Paul,
    I don't have any info on the total weight as I have not yet received the engine and installed all the accessory items. What I do know is that Pmags weigh less than mechanicals, magnesium sump lighter, lightweight starter, running full EFIS and LED lights allows a lightweight alternator, wood composite prop less than metal. I'll post some weights when I get to that point. I would refer you to Bill Rusk's detailed analysis of weight for his 0-360 engine. The Titan 0-320 is roughly ~ 20 lbs lighter with comparable accessories. The criteria for my engine selection were:
    1. I'm a big guy (some may say not so bad looking) and want to carry dogs/stuff/wife (note the order) for trips
    2. I need to fly over mountains where I live
    3. Would like to use floats
    4. Need to use autogas at times
    That convinced me of at least 180 hp. You get a little more hp with the 0-370 at the 8:1 compression which allows for auto fuel. My all-out cost to have Jay build this up was ~$30K. This is a significant investment for most of us, and the old trade-off of time versus money came into play. Believe me, if I had more time I would consider what Christian Sturm did and overhaul an engine under the supervision of an IA just to get the experience and learnings.
    Hope this helps
    Wendel
    Thanks Paul Heinrich thanked for this post
    17,616
    Curious about the choice of the lowered engine mount especially on floats. Wouldn't that put the prop in the spray more?
    Bill Rusk's Avatar
    4,859
    Actually no. When you do the Thrustline, it raises the front of the engine about 2 inches. Thus the kink in the cowl look. By lowering the mount it puts the prop (front of the engine) in its original location, so you get the thrustline improvements without loosing the over-the-nose visibility and it makes the front of the Cub look normal again ie no kink in the cowl.
    Yes, the prop would be lower but not lower than a “stock” Cub
    Hope this helps
    Very Blessed.
    17,616
    That makes sense. Was helping a friend pick out the options on his Javron kit and this one didn't make sense to me. I want the most prop clearance I can get and really didn't notice any visibility issues with the Thrustline modification but I dropped my nose bowl down and run a Baby Bushwheel.
    Likes JeffP liked this post
    3,531
    So it's more corrected than lowered? So why is there an exhaust fit problem? My mount is lowered. Clint at Vetterman has the exhaust solution. One comment I've heard about my plane is that it's quiet compared to other Cubs. Nice surprise!
    2,020
    Quote Originally Posted by wdoubleday View Post
    ….I don’t know if Jay would be willing to run an engine on his test stand that he did not build, but no harm in asking him.
    IMHO doing a "run-in" on an engine stand is a darned good idea, way better than starting from scratch with the fresh engine hung on the airplane.
    While not a "break-in" by any means, a proper run-in is a great start for a successful break-in.
  1. L-21 Javron
    By avnxtek in forum Member Projects in Progress
    Last Post: 10-09-2018, 06:17 AM
  2. Progress on Javron Cub
    By wdoubleday in forum Experimental Cubs
    Last Post: 08-03-2018, 01:01 PM
  3. 200 hp Javron
    By elpcub in forum Cafe Supercub
    Last Post: 04-01-2018, 08:47 PM
  4. New Javron Build
    By flyanozira in forum Cafe Supercub
    Last Post: 11-06-2015, 08:08 AM
  5. Jasperfield's Javron
    By Jasperfield in forum Member Projects in Progress
    Last Post: 06-18-2015, 03:49 PM
