Results 1 to 6 of 6
Thread: Question on a o290-D2
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    122
    Does the Lycoming 0-290 and 0290 D2 use the same cylinders
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    580
    Yes and No Doug.
    The clyinder is the same but valves are different intake is larger and its not as simple as just regrinding the Allison seat as you will have to remove so much metal to get the tulip to fit you wont have enough left to dissipate the heat.
    So really only way to convert them over is to remachine the cly head to accept the larger Allison seat for the 0320 size valve. Gets iffy then as you will want to go 1/2" vs the old 7/16 stems, now your into new guides........
    So it winds up as a " White tag" instead of a "yellow tag" rebuild. I had Divco do a few sets with 0320 valves, seats
    And guides. They work great but sorta in the " grey area".
    Thanks flynlow thanked for this post
    n40ff's Avatar
    Oct 2009
    WV
    854
    Certified? If experimental the most cost effective thing is to machine the cases to use O320 cylinders. Certified, you have to pay for high $ O290 parts unless you find a bard full of NOS cylinders at a yard sale.
    Mar 2016
    Vermont USA
    548
    A little spin off on this question. I have an O-290 here that has been sitting, never run for about 25 years. It has an O-360 oil sump & tag on it such that this would be EX only and obviously quite misleading to what the engine truly is.
    Is there an easy visual from the outside if this might have the larger or smaller intakes in it?
    supercrow's Avatar
    Dec 2008
    252
    Maybe you could take a rocker cover off and check valve stem size?
    Mar 2016
    Vermont USA
    548
    Quote Originally Posted by supercrow View Post
    I expect I did not pay enough attention to the intake stems when I put this engine up on a work stand last spring. Easy enough to do later today.
  1. o290 Question
    By Taledrger in forum Cafe Supercub
    Last Post: 02-07-2010, 06:28 PM
  2. Looking for: Lyc O290-D2 Cylinders
    By mikelima in forum Cafe Supercub
    Last Post: 12-27-2009, 07:25 PM
  3. o290 to o320 in pa-12
    By porti in forum Modifications
    Last Post: 11-28-2006, 12:20 PM
