Results 1 to 36 of 36
Thread: Best prop for a (certified) PA-18.
    Aug 2018
    26
    Hello all you cub experts. Iím new here!
    what prop could you recommend?
    with 180 HP I belive is taking of quickly?
    better cruise performance is the only.
    which prop would you recommend?
    1,499
    What type of flying will you be doing. Mostly paved/grass strips, Sandbars/gravel strips, or hardcore brush cutting mud slinging strips?
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    285
    What does the STC say you can use?
    Doug
    Thanks jokerswe2008 thanked for this post
    18,002
    You might want to read this thread. http://www.supercub.org/forum/showth...-for-O-360-C4P
    Sensenich will cruise faster, McCauley 1A200 will take off and climb way better but longer and needs extended gear or big tires. Look at your STC for the 180 hp engine.
    Likes WWhunter liked this post
    Aug 2018
    26
    it will be sandbars and fields when I have trained enough. I just got the tailwheel rating yesterday.
    I believe I should be looking for a climb prop.
    Something I don’t think is mentioned in the discussion climb/speed prop, is that a climb prop will help an inexperienced pilot to get out of trouble in takeoff and landing.
    Aug 2018
    26
    I got 26 ABW, 3’ extended gear and 180 HP. The STC does not cover all options.
    could I find the STC with the prop? (“With extended gear and 180 HP this prop can be used”)
    1,499
    The metal props will take a whooping and keep going all day long!! So if you said you would not be trimming any brush or slinging mud or rock into the prop I would go with a Sensenich. Nothing wrong with owning two/three props. Learning to do a proper off-field runup/turns/takeoff helps protect the prop. I believe you need 9 inches of clearance in level flight for a prop to be legal. Good news is now you might need a set of 31inch bushwheels!! The pitch is what will pull you off the ground and/or pull you faster. Example a 160 hp cub with borer 82/40 vs 82/43, at 2400RPM the 82/40 is 7 mph slower. You will loose 30-40 feet on takeoff with the 80/43 but it will still pull a massive load off the ground and get you home before the sun sets. CHT,s are 15-20 degrees cooler with the 82/40. The best thing to do is find someone that has one one you might like laying around (heck just pull it off his plane) and take it out for a week or two. Climb props are a lot of fun but it you want to fly 400-600 miles a day it can get old fast.
    Likes TurboBeaver, Brandsman liked this post
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    550
    Well since your "certified" then your certainly going to need a legal prop....... Even though a very high percentage
    Of Cubs being flown would likely not have the correct paperwork to satisfy a picky inspector....... So a compleately legal prop really isnt legal at all; unless you have all the Prop logs, (not likely)from one that Piper called out in the TC of your aircraft?
    If you slap a "Pawnee type" prop on, your going to need an STC for It ; on your "certified" airplane. And so it goes on and on
    Most prop STC's will call out some exact specs, but often props get Shortened and repitched out of those . However in real world flying; often times things are not always as it seams.( Some very interesting nomenclature hiding under lots of those spinners )
    Good luck finding a great prop for your cub, it is probably the one thing that makes any cub even better!
    18,002
    Your STC for the engine calls out the propeller approved for installation on your airplane. I believe both 180 hp STCs include bothe the metal Sensenich and McCauley 1A200. You should also have a flight manual suppliment with that info.
    18,002
    If you slap a "Borer" prop on, your going to need an STC for It ;on your "certified" airplane. And so it goes on and on
    Most prop STC's will call out some exact specs, but often props get Shortened and repitched out of those . However in real world flying; often times things are not always as it seams.( Some very interesting nomenclature hiding under lots of spinners )
    I have not seen prop logs until recent years. Haven't seen a requirement to have a prop log. An IA signs the airplane off as airworthy if he deems it so.
    Feb 2006
    Maine
    742
    As far as the getting an inexperienced pilot out of trouble NO PROP will do that it takes a lot of money and rebuilding of the airplane to do that after you learn the hard way. Practice short landing and take offs and there will still be a pucker factor for a while.
    Likes supercrow liked this post
    Jun 2009
    Northern Maine
    550
    Steve, I agree about prop logs. But thats the way its leaning. However like welding a simple tube into the topdeck, to Xbrace. Hundreds have em with no paperwork. Hundreds more have it with Atlees paperwork, that he would pass you for "nothing". But now that is all different: you legally need to bow down to Univar and pay for that, or you know the rest of the story...........
    The new generation of mechanics will have the paperwork all "perfect"; to cover their ass, and the airplanes will go out the door halfassed; because in the future because of govt policy, they will have the priorities backwards.
    If anyone wants to see how far out of control this govt is: Just keep watching this judge, trying to get appointed......
    Sep 2012
    Bettles AK & Arizona
    287
    If the paperwork doesn't take as long as the repair, you're doing it wrong - or so it seems. As far as prop logs. I get them wtih new props or overhauled but they never get a single entry in them until they are at TBO and go back to the prop shop. One sign-off is all you need for your annual/100 hour.
    S2D's Avatar
    Montana
    3,981
    If you want to get technical there is no requirement for a separate engine logbook either. ( See disclaimer below)
    2,300
    I dunno how they feel about prop logbooks,
    but I know a couple IA's who maintain that an entry in the engine logbook isn't required to document an annual inspection.
    One refused to put an entry in the engine book, and stuck to his guns even though it ended up losing him a customer.
    The other signed off in the engine logbook as a 100-hour.
    Maybe more IA's believe that, but most will put in an "inspected IAW an annual inspection...." entry anyway,
    as that's what the customer (the guy who's paying the bill!) wants to see.
    8,478
    ...but I know a couple IA's who maintain that an entry in the engine logbook isn't required to document an annual inspection.
    Those IAs are correct. It is the air frame which gets the annual inspection. Any work which is done to the engine at the same time is only incidental work on the engine. Only that work should be entered in the engine log book. There was a very good all around nice guy FAA man by the name of Bill O'Brien. He was the head guy in Washington in charge of all of the FAA inspectors who oversee all of the IAs World wide. He used to travel around giving talks at the annual IA meetings. I heard him tell the IAs at one of those meetings that the Annual inspection is only signed off in the airframe logbook. Not in the engine log.
    That customer who disagreed and took his plane elsewhere has lost the services of an IA who knew what he was supposed to be doing.
    S2D's Avatar
    Montana
    3,981
    I've got the article he wrote in one of the Aviation publications about that saved somewhere.
    another take on the issue ( not mine )
    ALL props come with log books! They have to, they're Type Certificated Products. It seems though that the fixed pitch props are in the Rodney Dangerfield category and don't get enough respect. You know, the late, great Bill O'Brien once told me [paraphrased] I don't care if you make your entry on a piece of toilet paper and staple it between two brown paper bags-that's a log entry! And he's absolutely correct! It's not the wrapping that makes the statement, it's the contents inside...
    I think the writer is confusing logbooks and aircraft records, but that's another issue.
    2,300
    ….That customer who disagreed and took his plane elsewhere has lost the services of an IA who knew what he was supposed to be doing.
    I know the IA in question and it wasn't a great loss IMHO.
    He was a know-it-all type and had the bad habit of trying to make sure everyone knew how smart he was,
    to the point of unnecessarily costing his customers money & down time.
    FWIW the logbook issue I mentioned came up as a renter was taking his PP checkride in the airplane,
    and the DPE (apparently wrongly) decided that the airplane wasn't airworthy because of no annual inspection entry in the engine book.
    Applicant went home, complained to the airplane owner, who complained to the IA.
    Owner wanted an engine book entry, the IA refused, so that was the end of that business relationship.
    Oh yeah, that customer was the airport owner, the resulting hard feelings culminated in the IA getting kicked off the private airport.
    The whole drama could have been avoided if the IA had just p
    ut an entry in the engine book--
    after all I don't believe it's illegal to do so, just not required.
    FWIW right or wrong, when I pay someone for an annual inspection, I expect (and get) entries in all three logbooks.
    Thanks pfm thanked for this post
    S2D's Avatar
    Montana
    3,981
    Student and owner should file a complaint with the faa against the DPE.
    If I was still doing customer annuals and an owner wanted it in all of the log books. id do it and charge him according.and I would say aircraft in each entry because I can't annual a propeller
    See if you can find the word log booK referenced in any FAR for anything but pilot records.
    S2D's Avatar
    Montana
    3,981
    Delete duplia cate
    10,117
    Yep, had a quiz right after my latest annual was signed off: IA showed me airframe log, “Inspected IAW an annual” Gaza, ya a..... then he showed me engine book.....entry was inspected IAW 100 hour inspection. I said looks good to me but why do I need a 100 hour on the engine? He smiled, I smiled, I passed.
    1,191
    Can't the IA say "Inspected IAW manufacturer's ICA and found airworthy at this time" in the engine and prop logs? Or something similar.
    8,478
    Ah Hah! The rest of the story. In this case the DPE was uninformed as to the annual records requirements. The entries in the engine and propeller logs should not refer to an annual inspection, only to that work which was accomplished on that product.
    May 2017
    279
    And the PP applicant was unprepared and didnít understand the regulations sufficiently to explain it to the DPE. 91.409(a) specifies ďAircraftĒ there is nothing in 91.409 that says engine or prop. 43.11 provides the correct words to be used for inspections, and 43.9 identifies what needs to be recorded for maintenance. Finally 91.417 covers what maintenance records are to be kept. If the student/applicant canít articulate that, he shouldnít pass the test.
    S2D's Avatar
    Montana
    3,981
    I sincerely doubt any one of us know the nuances of every applicable FAR. We couldn't even get people to agree on flying in Class E airspace if there was a cloud over the airport.
    Even if he knew it, I doubt he could get the DPE to change his mind. Had one here the same way.
    Try arguing with an FAA inspector when he's wrong.
    Likes WWhunter, hotrod180, Hardtailjohn liked this post
    May 2017
    279
    I have, and actually went and flew an aircraft he questioned the Airworthiness on and I challenged him to file a violation on me and told him Iíd see him in court if he did.
    8,478
    That is so much fun when you know that you are right. Just eliminate the arguing and replace it with explaining. When you do this often enough the FAA inspector will respect you and come to you for advise. I used to work for a respected old timer who used to tell the FAA inspectors to "go jump in the lake" and they would respond with "which one?".
    When you have earned the FAA's respect, doors will open.
    Likes WWhunter, mam90, Steve Pierce liked this post
    S2D's Avatar
    Montana
    3,981
    I asked my inspector once if we needed a compass in a Part 137 spray plane. Instead of a discussion on the regs he just said cause that's the way it came and went and inspected all my planes to make sure they had a compass in them. I don't ask questions any more.
    S2D's Avatar
    Montana
    3,981
    I have, and actually went and flew an aircraft he questioned the Airworthiness on and I challenged him to file a violation on me and told him I’d see him in court if he did.
    Just to play devils advocate, the same wording is used for 100 hr as is used for annual in 91.409. Yet per 65.85 and 65.87 the mechanic can sign off just the airframe or engine. I think this is where all the misunderstanding came from and at some point the FAA was telling people it had to be done that way.
    2,300
    And the PP applicant was unprepared and didn’t understand the regulations sufficiently to explain it to the DPE. 91.409(a) specifies “Aircraft” there is nothing in 91.409 that says engine or prop. 43.11 provides the correct words to be used for inspections, and 43.9 identifies what needs to be recorded for maintenance. Finally 91.417 covers what maintenance records are to be kept. If the student/applicant can’t articulate that, he shouldn’t pass the test.
    Wow, you're a tough grader, I'm glad I didn't do my checkride with you!
    And good luck "explaining" to the DPE.
    Don't think I've ever met one that would allow himself to be corrected by a mere PP applicant.
    I guess the proper response would be to fail the student, sue the DPE, and award a gold medal to the IA.
    Wouldn't it be an easier "path to yes" to just put the entry that most people expect to see in the engine logbook?
    If I was still doing customer annuals and an owner wanted it in all of the log books. id do it and charge him according. and I would say aircraft in each entry because I can't annual a propeller. ...
    "Aircraft" is fine, substituting "engine" and "propeller" respectively would be better.
    Is it that big of a deal? Would you lose a customer just to stand on your principals?
    And just how much more would you charge for making two more entries?
    Most IA's print out logbook entries on labels and paste them into the logbook.
    I figure it'd take about 5 minutes to modify the entry twice ("airframe" to "engine" and "propeller"),
    print out 2 labels, and paste 'em in.
    Likes flyrite, Brandsman liked this post
    8,478
    Easier, Yes it would be easier. Eventually easier leads to many who are uninformed. Wouldn't it be better to inform people up front what the correct method is to do something? After all, repetition of something false does not make it right. Somewhere along the line that DPE didn't learn something and that something slipped through the cracks causing that PP applicant not to receive his license on that day.
    There are two ways to do something, a right way and a wrong way. Isn't it better to do it the right way the first time?
    S2D's Avatar
    Montana
    3,981
    Oh don't get me wrong, I put the 100 hr entry in the logbook for the next student that went to the DPE, but I also included a copy of Bill O'Briens article on the proper signoffs. Last one that went to him anyway, his DPE was jerked for other reasons.
    I'm not a total asshole, if someone wants a signoff in logbook, I will oblige them but it will be written my way. Probably something along the lines of :
    Date 11/11/2023 Tach Time XX Prop total time ZZ. NXXXX was annualed this date IAW FAR 43 app D and this propeller was found to be in airworthy condition as installed.
    Now what if he takes that prop off and has a different one put on 20 hrs later. Does the installing mechanic have to annual the new prop??
    What if The engine starts making metal 50 hrs later and it's replaced. Does the installing mechanic have to annual the engine or does just a signoff returning it to service suffice??
    Try putting a " and a list of discrepancies was provided to the owner" type of annual signoff in the logbook and watch a DPE squeal.
    S2D's Avatar
    Montana
    3,981
    This is exactly what happened with the old Control Zone snafu (now called ClassE surface area). A whole generation of pilots were told you couldn't go in one if the ceiling was less than 1000 feet or the visibility was less than 3 miles at the reporting station, and pretty soon it was Gospel that you couldn't regardless of what the FAR said.
    May 2017
    279
    Funny story about PP applicant questioning the examiner. When my daughter was going for her private glider ride (16 years old), the examiner asked her during the oral to explain the required entries in the log book for the glider they were about to fly. She looked at the log and noted that an AD and the annual were both 2 months out of date! The Examiner was just a little embarrassed given that the glider had been used by the school for 2 months out of annual. Oh yeah, she passed the check ride.
    WhiskeyMike's Avatar
    West Boxford MA
    834
    Compasses Spray plane
    For what little bit itís worth the old CAR Part 8 required equipment said that a compass was suggested equipment - but not required. I donít know about Part 137. I built a J-5 banner plane with a 180 hp in it and left the compass out on purpose. the FAA certified it (this plane only flew very locally)
    Thanks S2D thanked for this post
    S2D's Avatar
    Montana
    3,981
    Quote Originally Posted by WhiskeyMike View Post
    For what little bit itís worth the old CAR Part 8 required equipment said that a compass was suggested equipment - but not required. I donít know about Part 137. )
    That's why I wanted a little discussion on it.
  1. non certified floats on certified plane
    By swoeric in forum Float Operations
    Last Post: 12-21-2017, 06:35 PM
  2. MT Composite Prop certified but Catto not certified
    By slowjunk in forum Cafe Supercub
    Last Post: 04-11-2017, 07:15 AM
  3. Replies: 26
    Last Post: 06-09-2013, 04:04 PM
  4. Certified or not??
    By NimpoCub in forum Modifications
    Last Post: 11-05-2011, 09:18 AM
  5. Experimental or Certified
    By Nathan K. Hammond in forum Tips and Tricks
    Last Post: 12-10-2002, 11:33 PM
Tags for this Thread
