Results 1 to 15 of 15
Thread: Float fittings template or dimensions, Wag 2+2
    RVBottomly's Avatar
    Sep 2017
    346
    As I'm at the fittings fabrication stage it seemed like a good idea to put float fittings on the fuselage I'm building.
    But, other than a few photos of items for sale, I can't find any sort of dimension or template for them.
    Right now I'm looking far down the road and considering Montana floats. After reading up on welded-on fittings, I'd like to do them now while I'm welding everything else. They don't look too complicated, but photos don't give a whole lot of info.
    Has anybody run across drawings of such fittings? I'd buy them if I could find them.
    Vic
    8,478
    Do you have the Northland PA-18 drawings DVD? They are on it. Both the weld on type and the EDO bolt on type.
    RVBottomly's Avatar
    Sep 2017
    346
    Yes, I do. I'll have to look again. I was going through them last week and didn't see anything right off.
    Vic
    RVBottomly's Avatar
    Sep 2017
    346
    Follow up: DUH!
    There is a folder titled "Float Brackets" in my Northland collection. It has exactly what I was looking for. Thanks again.
    Likes mike mcs repair, CharlieN liked this post
    jimboflying's Avatar
    May 2005
    470
    Remember that float fittings for a PA18 are not the same as the PA12-14.
    Likes mike mcs repair, TurboBeaver liked this post
    8,478
    Quote Originally Posted by jimboflying View Post
    That is true for the bolt on fittings. The main difference is the length and angle of the wire pull portion of the fitting. The weld on fittings with the flexible wire pull and strut connections should work on all three planes.
    RVBottomly's Avatar
    Sep 2017
    346
    I was wondering about your airplane, Jim. I've tried to see how Mr. Faust was arranged but the video goes by too fast!
    9,815
    bottom cross to longeron to side tube angle is different....
    8,478
    Which is why the weld on fitting would be best. Bend to fit, then weld.
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,299
    I still have the printable templates on my web site for self fabrication.
    Bugs
    http://www.supercubproject.com
    RVBottomly's Avatar
    Sep 2017
    346
    OK. I think I can fabricate them, but I'll still have to get angle information from whatever float maker I'd go with before welding them on, right?
    supercrow's Avatar
    Dec 2008
    247
    Quote Originally Posted by RVBottomly View Post
    No, not necessary with the weld on as you will have adjustable fittings for both the struts and the wires, as skywagon said.
    RVBottomly's Avatar
    Sep 2017
    346
    Thanks, supercrow. I was looking at pictures of weld-ons you could buy, and it looked like there were several degrees of freedom.
    supercrow's Avatar
    Dec 2008
    247
    More that several degrees, the fittings that attach to your weld on will pivot to accept the strut and the wires. Piece of cake if you buy ready made fittings rather that fabricate you own; but you certainly could if you had some to look at. I also fly experimental and I bought fittings from Nick Smith Cubs for about half of what most cost and they are of good quality. And I know he makes them for most cub style fuselages.
    8,478
    Be aware that when the bolt holes in the fitting are not parallel to the center line of the fuselage, the blocks which connect the fuselage fitting to the rear float strut will be lefts and rights. I made up a complete set of attachment fittings out of wood for a test fit before making them from aluminum. This will be a fun project for your new mill.
    It's no fun installing floats when the fittings are not made to the correct angles. When you have the plane hanging from a hoist with no landing gear while trying to push the attaching bolts through the holes and a tap with a hammer will not work. When you have to clamp a couple of long 2x4s to the strut in order to twist the strut without moving the plane. Then trying to imagine the stresses which will always be built into the installation. Sometimes I wonder why more of these installations don't break off fittings in the rough water use.
  1. EDO 2000 float dimensions
    By daves123 in forum Cafe Supercub
    Last Post: 11-05-2015, 08:55 AM
  2. Float fittings
    By Senior in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 03-28-2010, 08:16 PM
  3. AN fittings, dimensions?
    By sekps in forum Cafe Supercub
    Last Post: 02-28-2005, 10:15 AM
