wdoubleday
Folks,
just wanted to pass along another experience I had in painting my fuselage. I’m using a two color paint scheme with sport yellow and battleship grey with black striping between the colors. Since the majority of the fuselage is yellow, I sprayed that first and let that cure for one week prior to covering and masking the yellow to shoot the grey. The black stripe was the last to be shot, covering all with the 3M masking film. I also let the grey cure for one week. Temps in Seattle area have been around 80 in summer. When I finished the painting and started to pull of the 3M masking film, to my horror I found a perfect decal transfer of the lettering on the film to the paint on my fuselage. It was only in sections, as seen in the attached picture. I tried water, then soapy water but to no avail. Can’t use any organic solvents.
Fortunately, my local NAPA store carries the 3M machine polishing compounds 06064 and 06068. I used an air driven 3M random orbital sander with cut foam pads. This worked beautifully to remove the lettering and did not dull the gloss sheen of the Stewarts paint. I followed up with Meguiars carnuba wax.
Everything that can go wrong did go wrong in my first attempt with Stewarts, much of which was from my own mistakes. This experience almost sent me over the edge, but all is good, for now.
Wendel
Wendel
