Results 1 to 9 of 9
Thread: Transponder encoder issues
    jimboflying's Avatar
    May 2005
    468
    ATC says that my reported altitude can jump 800-1000 feet without me changing altitude. What are the likely problem areas to look at?
    10,052
    Quote Originally Posted by jimboflying View Post
    Jim,
    Must be those new Keller flaps......sorry, couldn’t resist.
    Back to your normal broadcast.
    Likes kestrel liked this post
    9,651
    it's just measuring static pressure, where is your static sourced from?
    TirolCub's Avatar
    Sep 2006
    Austria
    192
    ... maybe your Altitude Encoder needs adjustment ? If it is an ACK01 it is simple, but you need an Avionics guy with the equipment. Hope that helps ...
    6,268
    Mine just quit. I "re-racked" the transponder, and re- secured the encoder to its mount, and back to normal. Only a year and a half, and those two things will be worthless!
    AK
    3,869
    Mine's gone wonky a couple of times through the years. I just have the avionics shop adjust and recertify it. Lake Hood airspace is sensitive to altitude so when the encoder is mis-reporting tower questions it. I just turn mode C off until I get it fixed.
    1,991
    Check the basics. Wire connector secure on encoder. Re rack the transponder. Check for loose wire connections at the back of the transponder. Check for leaks in the static lines. If there is still no improvement, have the encoder bench checked. It is most likely going to be an encoder issue, not transponder, as altitude is the only issue you report.
    Thanks jimboflying thanked for this post
    2,206
    I disagree.
    If you need a transponder & encoder where you fly, then you'll still need them in 2020.
    You will also need an ADS-B out system, in addition to the transponder.
    Some ADS-B systems incorporate a txp to replace your existing set-up, some are in addition to it.
    I will likely keep my "legacy" mode C txp, and add something like the Garmin GDL82.
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    285
    Local shop had some issues with an old encoder after an install, Now they install a new encoder as part of the install as standard procedure. The encoder was giving hem issues.
    Might be the real issue?
    Doug
  1. Replies: 3
    Last Post: 02-01-2018, 11:40 AM
  2. Altitude encoder allowable deviation?
    By StewartB in forum Super Cub Sick Bay
    Last Post: 04-29-2011, 06:39 PM
  3. Transponder DOA
    By OLDCROWE in forum Super Cub Sick Bay
    Last Post: 08-15-2008, 03:38 PM
  4. Com/transponder/encoder in non-electric airplane
    By d.grimm in forum Modifications
    Last Post: 05-10-2006, 07:37 AM
