Results 1 to 5 of 5
Thread: Replacing Whelen wingtip strobes
    Anne's Avatar
    SE Michigan
    1,685
    Hi all, has anyone replaced their wingtip strobes (not nav lights) with LEDs? I'd like to replace the whole set-up, including the power box. If so, what did you replace them with? Did you have to replace the wiring and switches too, or can those be re-used? Is there something other than LEDs that would work too?
    My plane is a homebuilt replica SC from scratch (not a kit), experimental, so anything that fits on a SC fits my plane.
    Thanks for your help!
    Baloney is still baloney, no matter how thin you slice it.
    Thanks Seaworthy thanked for this post
    4,274
    Anne,
    You can find direct replacement (same footprint) LED strobes with or without nav lights built in. Figure out your strobe footprint and go browse the airplane parts websites. You can use much of the wiring and the same switch but you won't need the power supplies. LED strobes run off of standard 12v. You can choose to run a wire between strobes to synchronize their flash timing but that isn't required.
    SB
    Thanks Anne thanked for this post
    Likes Brmoore liked this post
    10,017
    You may end up with radio noise, if so you would need to string shielded wire to them
    6,480
    I want a strobe bulb that has only two modes: flash, and off.
    Like flashlights, most bulbs have a sequence - off - on - strobe - off. I hate that.
    Hgr3029e's Avatar
    Jan 2015
    Santa Maria, CA
    18
    We are running Aveos.
    They are LED Strobe Nav and Position
    All the wiring runs off the nav switch.
    We installed these on our Experimental Sport Cub and are what are provided from the factory on the Carbon Cubs.
    No noise and very little draw. Same footprint as the standard nav/ strobe.
    We also went with the Aveo tail position and strobe. We are starting the same upgrade on my Sport Cub
    Scott and Kim Huntington
    2007 CubCrafters CC11-100 "Sierra"
    2008 CubCrafters Cc11-100 "Priscilla"
  1. Paperwork for the Whelen Wingtip and Tail LED lights
    By jerichod in forum Member to Member
    Last Post: 09-27-2017, 01:31 PM
  2. Replies: 3
    Last Post: 07-03-2013, 09:54 PM
  3. AveoFlash LED strobes?
    By TDTerry in forum Modifications
    Last Post: 10-24-2008, 09:08 AM
  4. Strobes
    By StewartB in forum Tips and Tricks
    Last Post: 03-27-2003, 08:52 AM
