Page 2 of 2 FirstFirst 12
Results 41 to 79 of 79
Thread: T3 field approvals?
  1. #41
    18,114
    You mention three pointing on rough terrain and thought maybe that was the way you landed a RANs. I wheel land most of the time for visibility mostly. Figured you can see over the nose easier in the RANs than I can with 3" extended gear, 31" BWs and the Thrustline modification. Never flown a RANs so I am pretty ignorant to their operation. Enjoyed visiting with Randy and Shelly in Perry, FL when we all got stuck on our way to Sun & Fun and learned a lot but still haven't flown one.
  2. #42
    Dec 2016
    Canyon, tx
    292
    I’m speaking out of turn but.....I’ve got an entire 10 min in a S7 with robertson gear. I flew it just like an -18, tail low wheel landings, tail comes right up on T/O. I thought the controls were crisper, you could crank the shorter wing and it had plenty of rudder/elevator. It flew better than the super cubs I’ve been in however it would kite a little because of its light weight. Good plane
  3. #43
    18,114
    So are you gonna nix the new SC and start working out of an S7?
  4. #44
    Nov 2017
    112
    A stock S7 is indeed a little easier to see over the nose. Mine has extended Roberts gear on 29Ēs
    so the vis over the nose is indeed restricted. Any of the 3 pt landings I do are in places Iím sure of whatís ahead, putting on the mains for good vis, though, as you say, is probably a better way.
    I have the privilege of flying my neighborís new Super Legend from time to time and itís amazing how similar these aircraft handle. As suggested already, the Legend rides the bumps better.
    Make no mistake, even though the RANS is not for sale, I am a Super Cub fan and would love to own a red and white Super Cub on floats. Now that would be ideal!
    Roddy
  5. #45
    18,114
    Talked with Randy quite a while when we were stuck in Perry and we discussed the two airplanes. It was interesting when we talked about the S21 and I asked why he went with the O-340 on the demo that had there. He said he did that to carry a load and it would do it well up to a pretty high altitude at close to 1500 ft per minute. It is interesting how all these airplanes are different yet similar. Even the differences between Super Cubs, Super Legends and Carbon Cubs. Of course it is hard to find two Super Cubs that are the same or fly the same.
  6. #46
    Dec 2016
    Canyon, tx
    292
    No, the Rans will fly way faster than I can think. That’s what 35s on an -18 are for. To slow the whole process down to my single digit IQ way of thinking
    Likes RaisedByWolves, mike mcs repair liked this post
  7. #47
    18,114
    What is the useful load on an S7 vs a Super Cub? How much do you carry in anvils and hammers on a regular job?
  8. #48
    9,891
    Iíll split one with you Pierce. Run it for a min. If you like it buy my 1/2 and sign my logs as a minor alteration for the one I buy. If you donít like it, Iíll buy your half and pretend to sign my own logs......Brandt likes his on the Rans
    in jest...
    if you as a pilot think it falls as a minor, and you are allowed to change landing gear parts (wheels/ski's) and log it... why don't YOU log it....????
  9. #49
    Dec 2016
    Canyon, tx
    292
    There’s not as much useful load difference as a person thinks between a sub 800lb S7 and a 1150lb -18 given the cub is 1750 gross. The Rans will go as far as a cub on 1/2 the fuel......on the horse shoeing question, 125-50lbs is about what I carry on a normal day trip. Some of the ranches have anvils I’ve left or I carry a stall jack which is an abbreviated anvil on a tripod type stand.
  10. #50
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    710
    The 2000 lb gross weight mod requires the 4 leaf 1 1/2 tail springs.
    No ďminor changeĒ wiggle room with that.
    Ed
    Likes tripper liked this post
  11. #51
    Cubonaut875 SchulerJL's Avatar
    Aug 2009
    Peoria, Illinois
    568
    There is a field approval out there. PM me if you are really serious about going through the process
  12. #52
    18,114
    This guy has a done a field approval on a T3. gregory.horrell@faa.gov
  13. #53
    Nodak33's Avatar
    Sep 2016
    77
    On my last 12 I used the t3 after realizing how much abuses even taxiing put on the tail with a 6Ē ext. gear. On a 47 airframe it was a concern (or maybe me being overly paranoid)
    Once installed the dampening effect I found incredible.
    The side to side durability, obviously not so much as seen by the pics.
    I have been told that this has been remedied by a one piece billet aluminum arm, rather than the pictured style by the manufacturer. I have yet to send it back, since I am just finishing my new gear ext on a new airplane. But I will utilize it again given my experiences, even with this 2011 airframe.
    It is a very high quality product and particularly in a 12, when you have a nose high attitude in order to really get it slowed down on final, touchIng tailwheel first happens. This product absorbs and dampens that, thusly absorbing more of the energy rather than transferring it to the tail.
    Although I will/ have/ should get field approval this time.
  14. #54
    May 2014
    479
    I don’t think you’re being overly paranoid..
    http://www.lightaircraftassociation.co.uk/CE-13-14.pdf
  15. #55
    18,114
  16. #56
    cruiser's Avatar
    May 2002
    South Glens Falls, NY
    1,417
    There is no reference to a tail spring in the PA-18 type certificate. Why is it necessary to field approve or even mention a change?
    Thanks tripper thanked for this post
    Likes KevinJ liked this post
  17. #57
    gdafoe's Avatar
    Feb 2002
    851
    Does anyone have pictures of the newer version with the billet mount that they could post? It looks like the pictures on the Airframes site are of the older version. That area always looked like the weak link to me.
  18. #58
    3,639
  19. #59
    gdafoe's Avatar
    Feb 2002
    851
    Thank you, are both the front and back attach points milled out of solid aluminum?
  20. #60
    6,382
    Just looked at this - and notced Steve getting stuck in Perry. I too was stuck there the week before - low ceilings. Good folks let me keep the courtesy car for two days.
    When I got out, I managed to get to Nacogdoches, then the next day those low ceilings covered Texas!
    For some reason, my tailwheels just keep following me around, no matter what I do - except for the day an axle broke on 064. Then the tailwheel passed us on the runway. We made it back to the hangar on two wheels.
    Likes OzAK liked this post
  21. #61
    nd
    3,055
  22. #62
    18,114
    Ok, so you just post that picture without an explanation?
  23. #63
    9,513
    Silly boy, it's obviously a T3 tailskid for a pioneer or WWI aircraft
    Thanks C130jake thanked for this post
    Likes mike mcs repair, JP, aktango58 liked this post
  24. #64
    Upper Peninsula of Michigan
    376
    Well, I hope you at least found the tailwheel. They are kinda expensive. Lol. Nice field repair though.....what no duct tape
  25. #65
    Nodak33's Avatar
    Sep 2016
    77
    I do appreciate the custom fabrication... can I get copies of the field approval docs as well
  26. #66
    smutny's Avatar
    Feb 2017
    6
    Seriously? A Harbor Freight hose clamp?
    Amateur.
  27. #67
    nd
    3,055
    lookin for a field approval. anyone approve.
    Likes Nodak33 liked this post
  28. #68
    9,891
    Quote Originally Posted by smutny View Post
    Amateur.
    Iíve used a couple hose clamps on a split main front spar at fuselage end on a t craft for ferry flight. It did well for the 3 or 400 miles it needed to go to get home.
  29. #69
    smutny's Avatar
    Feb 2017
    6
    It was meant tongue in cheek. Sarcastic. Humor.
    Never mind.
  30. #70
    RVBottomly's Avatar
    Sep 2017
    353
    I do! Next time try bungees for extra bounciness.
  31. #71
    18,114
    What kind of airplane is it? Has some very distinguishing features but I can't place it.
  32. #72
    8,602
    A tail skid is better than a full castering tail wheel in preventing ground loops and in providing more angle of attack for lift off.
    Likes DENNY liked this post
  33. #73
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    122
    The original locking tail wheel
    Thanks DJG thanked for this post
  34. #74
    9,513
    Quote Originally Posted by Doug Budd View Post
    And a brake too
  35. #75
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,193
    I once saw a tailwheel sitting in the middle of the grass runway at Plymouth NH. Protesting, I think.
    Sent from my SM-G930R4 using SuperCub.Org mobile app
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    www.bloomerrussellbeaupain.com
  36. #76
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    1,897
    Quote Originally Posted by JP View Post
    I think thatís the difference JP. My wing had to be torn off. Your tailwheel simply decided to leave you on its own accord. Maybe it didnít love you as much?
    Likes mike mcs repair, JP liked this post
  37. #77
    JP's Avatar
    Mar 2003
    3,193
    True. It was mad at me because Ford was flying her instead of me.
    Likes Farmboy liked this post
  38. #78
    nd
    3,055
    a T3 suspension, what does the T3 mean??
  39. #79
    aktango58's Avatar
    18AA
    8,900
    I think that’s the difference JP. My wing had to be torn off. Your tailwheel simply decided to leave you on its own accord. Maybe it didn’t love you as much?
    It did not "need" to be torn off, nor 'had' to be torn off... you just did it on your own!
    I am calling Juneau FSDO tomorrow to see about a FA for these. If Greg allowed one, just maybe...
  1. Field Approvals
    By mit greb in forum Take Action Jackson
    Last Post: 06-08-2017, 01:04 PM
  2. Field approvals
    By Gordon Misch in forum Cafe Supercub
    Last Post: 12-10-2008, 01:11 AM
  3. Field Approvals, (Again)
    By T.J. in forum Cafe Supercub
    Last Post: 06-09-2006, 10:22 PM
