Page 1 of 2 12 LastLast
Results 1 to 40 of 79
Thread: T3 field approvals?
    Feb 2008
    Denver
    13
    T3 field approvals?
    Anyone try to get a field approval for the T3 tail suspension from Airframes yet? My IA would like at least one other and he's willing to try. Thx.
    Will
    Thanks 1piece@atime thanked for this post
    18,114
    Looking at CAR3 tail wheel/skid I don't believe you need one but I could be wrong.
    6,382
    My PMI wanted me to call my Grove masters a "minor alteration". He did sign the field approval a year later.
    cruiser's Avatar
    South Glens Falls, NY
    1,417
    Don’t see anything on the type certificate that mentions a leaf spring? Yea, I know everyone just knows that it is back there.
    Likes alaskadrifter liked this post
    Feb 2008
    Denver
    13
    You guys just make it too easy to spend money!
    4,090
    major alteration means an alteration not listed in the aircraft, aircraft engine, or propeller specifications -(1) that might appreciably affect weight, balance, structural strength, performance, powerplant operation, flight characteristics, or other qualities affecting airworthiness; or
    (2) that is not done according to accepted practices or cannot be done by elementary operations.
    minor alteration means an alteration other than a major alteration.
    Thanks Doug Budd thanked for this post
    18,114
    What are the reasons to install the T3? I wheel land so I can see, lift the tail on take-off as soon as it will come up which is quick, I don't land on big rocks, normally on sand and gravel mostly and see this as something else to fail and not easily be field repaired. Are folks seeing a huge advantage to the T3? Looks like a great design I just am curious how others use it.
    Likes mike mcs repair, Southern Aero liked this post
    Feb 2008
    Denver
    13
    My home field is clumpy prairie grass and the tail takes a beating on every taxi.
    Thanks Steve Pierce, Frank Blaesbjerg thanked for this post
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    122
    I have one on my cub and like it. I land a lot in pastures and my runway is a wheat field. Not as much banging going on back there. The down side is it is taller than springs
    Likes cruiser, cubdriver2 liked this post
    Nov 2017
    112
    One of the best mods on a Rans S7 for taxiing over and/or 3pt landing on rough surfaces. Especially
    if youíre making a first time off - airport landing in a place you havenít walked before, more peace of mind rather then punishing the tail end of your plane. Just simply takes a whole bunch of stress out of the tail section. Well built piece of gear. Never personally heard of one failing.(?)
    Went to Acme Aero Bush Shocks, T3 and 29Ē Airstreaks- if I owned a Cub, it would need the exact set up.
    Keep in mind, these items are manufactured and sold by companies with great reputations.
    Roddy
    18,114
    Before this turns into something it was not intended to be I have no issues with the quality of the product. I am merely asking how people are seeing the benefits. Things break period be it an anvil or a cylinder on an engine. I seem to keep my airplane simple unless I see a benefit in changing, adding or modifying it. The benefit has to out weigh the compromise which there always is one. Looks like there are several benefits to the T3 depending on what, how and where you operate. Hope to hear more.
    Likes mike mcs repair, MT12 liked this post
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    122
    Steve if I flew off of a smooth surface and only landed off airport once in a while I would probably stay with a springs. But 90% of my take off and landing are off airport so I think it is worth it. Time will tell if it can hold up.
    Likes MarkS liked this post
    18,114
    Quote Originally Posted by Doug Budd View Post
    I am in the same boat but the off airport places I go are pretty smooth. I have talked to Dan several times and keep weighing it out in my mind.
    Thanks cubnut thanked for this post
    4,090
    A little too much lateral play for my taste. I had a T3 in hand. I still have the parts for Backcountry's swingarm tail suspension. I installed a Pawnee spring.
    9,513
    It's like adding Dr School's to the rear of your plane. It stops most of the stress that the spring transfers to the frame, on every landing, even the smooth ones.
    I have a dirt farm road crossing my runway that has 4" tire ruts. I used to fill it in after every rain. I don't even bother since installing the T3. Love mine.
    Likes Chicken Hawk, 40m liked this post
    May 2014
    479
    Iím with Glenn,
    Totally eliminates elevator bounce felt thru the stick when on rough stuff.
    Re lateral flex, way better than stock spring.
    Nothings as stiff as a Pawnee spring because itís designed for a 250 lb tail
    and unnecessarily beats the crap out of the airframe in my opinion.
    T3 is a good compromise.
    Re loss of AOA: half inch alum spacer block between front mount pad corrects TW angle.
    might also allow the steering head to hit rudder when totally compressed, one ought to take the spring off and check full range of travel before taking my advise.
    T3 assy weighs about the same as a Pawnee spring BTW.
    I rarely fly over 1500 lbs, so, canít speak for heavier applications.
    Thanks Brandsman thanked for this post
    Likes Chicken Hawk, Frank Blaesbjerg liked this post
    May 2017
    285
    You would need to do drop tests to get an approval. You need to show compliance to CAR 3.352.
    David
    9,513
    You can get the AOA back once moving because the T3 will compress when pulling back on the stick
    Likes Frank Blaesbjerg liked this post
    Feb 2008
    Denver
    13
    Gabe at Airframes said they have several customers working on approvals and would update the website when and if they can get copies of those.
    Will
    May 2014
    479
    i agree but I think the steering head angle is too steep and makes for a floppy tailwheel during ground ops.
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,239
    About a month ago saw a YouTube video on Facebook about a composite Tailwheel spring. Can’t find it now.
    Anyone know about this.?
    Think I located it.
    https://www.facebook.com/mark.patey/...c_location=ufi
    "...We're fast enough to get there, But slow enough to see..."
    Fron the song "Barometer Soup". By Jimmy Buffett
    Thanks Orchevguy thanked for this post
    Likes Orchevguy liked this post
    Nov 2017
    112
    Quote Originally Posted by Oliver View Post
    Not my experience at all. One person in the plane, or two, steering remains excellant.
    (Matco tailwheel assembly attached to the T3, also good equipment).
    Roddy
    8,602
    Hmmm? So with the spring compressed, how well does it traverse the bumps? It seems that you would be sacrificing the advantages of the T3 for angle of attack. Perhaps it would be advisable to increase the diameter of the main tires when the T3 is installed in order to retain the angle of attack if it is that critical?
    18,114
    Quote Originally Posted by RoddyM View Post
    Roddy
    Super Cub or a RANS?
    10,166
    But, do you really want to to so on rough terrain? I prefer to get the tailwheel OFF the surface, not put more pressure on it.
    18,114
    Quote Originally Posted by Ruffair View Post
    A friend sent me some pictures. I hear it has withstood installation on a Husky which I believe are heavier on the tail than a Super Cub. Only issue I see is taking weight off the wrong end.
    Thanks Ruffair thanked for this post
    10,166
    Thomas Dietrich (Solo Aviation) in Germany produced a composite tail spring for Huskys.
    9,513
    [QUOTE=mvivion;7214a But, do you really want to to so on rough terrain? I prefer to get the tailwheel OFF the surface, not put more pressure on it.
    MTV[/QUOTE]
    Of course not, but available if needed. I don't have a big engine, big prop or flaps so I need to use all the tools I can find.
    8,900
    I would consider moving the road!
    4,090
    Early in my project I considered a composite leaf spring for the tail. I even talked to a manufacturer who was interested in making it for me. I had more on my plate than I needed so I never followed through.
    Corvettes have used composite leaf springs for as long as I can remember so obviously they aren’t a new idea.
    I saw a pic on Facebook not long ago that appeared to be an Acme Aero Fab tail suspension being tested. No info on Acme’s website.
    Mar 2015
    150
    I have the composite tailspring on my Husky made by Thomas Dietrich in Germany, STC for tailski, so all good. It works well for me. Removed 5 lbs from tail compared to stock spring, but I also removed a lot of weight forward to help offset matters. Thomas has just finished doing a forged steel one piece spring for the Husky which is only one pound more weight than the composite one he says, have not seen that yet, only in pictures.
    John
    9,513
    I would if I owned it, but not that big of a deal, been there for over 20 years. Only gets interesting when they appear out of the trees with a tractor, bailer and haywagon just as you touch down
    Thanks Bender thanked for this post
    4,090
    Nov 2017
    112
    RANS
    Roddy
    18,114
    RANS
    Roddy
    Different ball game all together. My question was more to the Super Cub guys since that is what I would run it on. RANS is probably a lot lighter and lots of differences over a Super Cub.
    18,114
    Quote Originally Posted by john schwamm View Post
    John
    What does the composite spring weigh? Here are some weights I have of tail springs:
    AK Bushwheels 3 leaf tail springs 4.85 lbs. with their bracket 5.05 lbs
    Univair 3 leaf from 1 ľ” 3.10 lbs.
    Univair Pacer/Super Cub 4 leaf 4.20 lbs with Piper bracket 4.35 lbs
    Univair Pacer/Super Cub 4 leaf with bracket holding springs together 4.50 lbs
    4 leaf Pawnee tail spring 6.2 lbs.
    Husky Spring pack 4.875 lbs.
    Thanks Bowie, Brandsman thanked for this post
    Dec 2016
    Canyon, tx
    292
    I’ll split one with you Pierce. Run it for a min. If you like it buy my 1/2 and sign my logs as a minor alteration for the one I buy. If you don’t like it, I’ll buy your half and pretend to sign my own logs......Brandt likes his on the Rans
    Likes RaisedByWolves, mike mcs repair liked this post
    9,513
    Eddy Doyle bought one at Kosh 2 years ago, does he like it?
    18,114
    You always tend to come out smelling like a rose on any deal you make. I'll let you buy one and try it out. When did you ever worry about logbooks?
    Likes KevinJ, mike mcs repair liked this post
    Nov 2017
    112
    Not so Sir. With all due respect, these aircraft are more similar then you think.
    Roddy
  1. Field Approvals
    By mit greb in forum Take Action Jackson
    Last Post: 06-08-2017, 01:04 PM
  2. Field approvals
    By Gordon Misch in forum Cafe Supercub
    Last Post: 12-10-2008, 01:11 AM
  3. Field Approvals, (Again)
    By T.J. in forum Cafe Supercub
    Last Post: 06-09-2006, 10:22 PM
