Thanks Thanks:  0
Results 1 to 8 of 8
Thread: Flying without spinner
    Mar 2007
    Alaska
    94
    I Think I remember reading here somewhere someone talking about saving 2 pounds of weight on a nose heavy airplane by flying without a spinner.
    What's the down side to flying without a spinner? How much speed loss, cooling considerations?
    G44's Avatar
    Oct 2011
    SW Michigan
    294
    Higher CHT (possibly).
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    199
    Some engine/prop/aircraft combinations require spinners for engine cooling purposes.
    17,143
    I removed the spinner on my 150 hp Super Cub and saved 2.7 lbs. I haven't noticed any difference in cooling but don't have CHT/EGT instrumentation eaither. I know the engine will overheat on a Cessna 182 but have seen no issues with Super Cubs. I don't see the spinner on a required equipment list.
    Dec 2016
    Canyon, tx
    139
    I could detect no real difference in speed loss or temps after removing the spinner. I was flying behind a cgr-30.....When your airspeed is measured in days instead of Mach #s, I don’t think deleting the spinner matters. Maybe you could detect a slight speed loss if you had a slicked up cub with a cruise prop and little tires?
    jnorris's Avatar
    May 2002
    Wisconsin
    738
    I was flying without a spinner on my Pacer back in the day, and an FAA guy came up and said "Wasn't that airplane certificated with a spinner?" That's all he said, and he walked away, but I got the point. Check to make sure it's not required equipment per the TCDS if it's a standard category airplane.
    Joe
    Likes N86250 liked this post
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    370
    I have had my spinner on an off a couple of times on an O.375 where I watch the temps carefully. Haven't noticed anything yet.
    Back Country O-375 wide body extended wing cub
    Binty's Avatar
    Jan 2005
    South Island, New Zealand
    364
    No difference what-so-ever.
    If you force it, it will fit
  1. spinner gap?
    By jon in forum Experimental Cubs
    Last Post: 05-31-2006, 08:04 AM
  2. Spinner/ No Spinner
    By wingnut18 in forum Cafe Supercub
    Last Post: 04-21-2006, 04:00 PM
