Results 1 to 8 of 8
Thread: Flying without spinner
    Mar 2007
    Alaska
    94
    I Think I remember reading here somewhere someone talking about saving 2 pounds of weight on a nose heavy airplane by flying without a spinner.
    What's the down side to flying without a spinner? How much speed loss, cooling considerations?
    G44's Avatar
    Oct 2011
    SW Michigan
    294
    Higher CHT (possibly).
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    199
    Some engine/prop/aircraft combinations require spinners for engine cooling purposes.
    "There are 3 kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves." Will Rogers
    17,143
    I removed the spinner on my 150 hp Super Cub and saved 2.7 lbs. I haven't noticed any difference in cooling but don't have CHT/EGT instrumentation eaither. I know the engine will overheat on a Cessna 182 but have seen no issues with Super Cubs. I don't see the spinner on a required equipment list.
    Dec 2016
    Canyon, tx
    139
    I could detect no real difference in speed loss or temps after removing the spinner. I was flying behind a cgr-30.....When your airspeed is measured in days instead of Mach #s, I donít think deleting the spinner matters. Maybe you could detect a slight speed loss if you had a slicked up cub with a cruise prop and little tires?
    jnorris's Avatar
    Wisconsin
    738
    I was flying without a spinner on my Pacer back in the day, and an FAA guy came up and said "Wasn't that airplane certificated with a spinner?" That's all he said, and he walked away, but I got the point. Check to make sure it's not required equipment per the TCDS if it's a standard category airplane.
    Joe
    Likes N86250 liked this post
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    370
    I have had my spinner on an off a couple of times on an O.375 where I watch the temps carefully. Haven't noticed anything yet.
    Binty's Avatar
    Jan 2005
    South Island, New Zealand
    364
    No difference what-so-ever.
    If you force it, it will fit
  1. spinner gap?
    By jon in forum Experimental Cubs
    Last Post: 05-31-2006, 08:04 AM
  2. Spinner/ No Spinner
    By wingnut18 in forum Cafe Supercub
    Last Post: 04-21-2006, 04:00 PM
