Results 1 to 8 of 8
Thread: Rudder Hinge Pins
    Jun 2015
    6
    Rudder Hinge Pins
    I do not have sufficient information or evidence for a serious discussion, so for that I apologise. I have therefore deleted my contributions as I cannot see how to delete the thread. Sorry for wasting anyone's time.
    behindpropellers's Avatar
    NE Ohio
    6,582
    Quote Originally Posted by EnglishNeil View Post
    There was an incident last weekend where the top rudder hinge pin sheared on a J3. Fortunately the experienced pilot landed safely but not without damage, the rudder detached and interfered with the elevator.
    Does anyone know of any similar incidents on other J3's or indeed PA18s?
    I'm not sure if the pin is the same part number on the PA18 as the J3, can anyone advise?
    How about more detail on this?
    Do you have a picture of the pin? Of the Sheared pin in place?
    Citing an issue without finding the root cause really doesn't accomplish much.
    The pin is an AN clevis pin, either 392 or 393. It would take some serious force to shear one.
    The
    Jun 2015
    6
    8,920
    picture please.
    I doubt it sheared...
    (if it's same as a -18 )someone probably forgot to put a washer on head and the bushing and all fell out, the clevis bolt head is smaller than the bushings, and you MUST have a washer on head side
    http://www.aircraftspruce.com/catalo...lickkey=784308
    Mar 2016
    Vermont USA
    358
    I have a hard time trying to understand how a properly installed and maintained hinge pin would fail. Was this pin just installed recently? Or was it in there for decades? I can not imagine the loads involved to shear a maintained pin. Even a low grade hardware store pin would hold the rudder loads in that plane.
    Jun 2015
    6
    Aug 2003
    1,266
    EnglishNeil, do not feel badly: You asked a legitimate question, and got some straightforward replies. This highlights the importance of a thorough, detailed preflight inspection. On two occasions I've "broken" Supercubs, just by looking at the rudder hinge pins, in both cases the split pin securing the castle nut was missing (how? I don't know). An easy repair.
    I hope you continue to feel welcome here.
    Thanks. cubscout
    8,920
    my point being.... if it was sheared, that would mean it was STUCK in all 3 parts/bushings, and the pin/or most of the pin parts would still be stuck there after landing..
    it fell out.... probably cotter key went away.... if bushings still there as you said
  1. cotter pins
    By RAC cubs in forum Cafe Supercub
    Last Post: 11-29-2016, 10:02 AM
  2. Piston Pins
    By scott c in forum Cafe Supercub
    Last Post: 11-19-2015, 08:22 AM
  3. Pins in door
    Last Post: 03-12-2015, 04:44 PM
  4. Wrist Pins
    By Roger Peterson in forum Experimental Cubs
    Last Post: 11-27-2006, 08:31 AM
