Results 1 to 35 of 35
Thread: Advice on bush upgrades
    Bellingen, NSW, Australia
    705
    OK, after 16 years of tooling around I am finally going to make my largely stock PA18-150 bush-ready. It has just had the engine zero-timed and upgraded to 160HP and currently has a 74-54 Sensenich. The aircraft will be used on gravel bars, beaches and tundra.
    Definitely in: 31" Bushwheels, baby bushwheel, Piatt baggage pod with a couple of AK Bushwheels 5 gall fuel bladders.
    What else do people strongly recommend?
    Extended gear? What's the advantage?
    Extended baggage?
    Is there a cargo net available?
    Am waiting for the Catto prop STC (foolish, perhaps).
    Anything else?
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,417
    The Baby Bushwheel is questionable. Several people have installed them and then decided they didn't like them so much. Myself included. They add weight and steering effort. They're also more prone to shimmy as the tail spring flattens out over time and cost you a little effective incidence/deck angle. When operating in the rough I'm almost always solo and it's easy to lift the tail almost immediately on takeoff and keep it unweighted until nearly stopped when landing with forward stick and judicious braking.
    Likes Oliver liked this post
    705
    Interesting, thanks.
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    355
    Can you you zoom in on the tail wheel?
    behindpropellers's Avatar
    NE Ohio
    6,575
    Borer or Cato prop
    Belly Pod - Don't extend the baggage.
    31 or 35s
    Safety Cables
    2000 gallons of avgas so you are proficient.
    Likes J5Ron liked this post
    8,687
    Quote Originally Posted by BritishCubBloke View Post
    Extended baggage?
    Anything else?
    It's ready now without all the added weight.
    Likes Colorguns liked this post
    RaisedByWolves's Avatar
    Feb 2005
    3,256
    Itís fine until you land somewhere and didnít see that hole. I do recall you saying how you can go everywhere on 800x4 or your 25x4 yet I havenít seen you take your Bushwheels off. Put the 800ís on and follow me. Iíll bring the video camera.
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    3,984
    Donít follow Tom. He might land below a dam somewhere.
    Thanks gmcmillan thanked for this post
    Likes RaisedByWolves, OLDCROWE liked this post
    8,687
    Ok, add some 26s, the rest we do for ego
    8,506
    Don't like your baby bushwheel? Send it to me!!
    If you are in sand with any weight, or rough, get the baby. I used to go through two hubs each year breaking them on the rocks. The baby bushwheel took care of that. Steering in sand is much better with big tires.
    Flatter prop, practice, and a cover for the back stick to ensure it does not get stuck or wedged.
    Cables, I like long gear for prop clearance.
    From there grass stains and rock nicks from using it- and lots of smiles while you do that.
    Likes RaisedByWolves, dryfarmer, Bender liked this post
    Feb 2005
    3,256
    It was pretty smooth on 35ís ha ha
    Feb 2005
    3,256
    So when you going back on 25ís and following me?
    8,687
    It’s fine until you land somewhere and didn’t see that hole.
    That why the real bush pilots drag a landing spot 4 or 5 directions first before just doing it.
    Feb 2005
    3,256
    Soooo when are you going to follow joe and I on your little tires?
    9,641
    I seem to recall you have stock tanks. I’d go with a combination pod or bigger tank(s) before anything else. Those gas bags MAY leak, mine does. And manhandling those around, with potential for spillage/hassles/contamination just isn’t worth the hassle to me. Get a proper fuel system that meets your needs, then the gas bags are just gravy if you WANT to go farther.
    im not a big fan of the baby Bushwheel. On pavement, they shimmy. Learn to manage your plane and they aren’t needed. Long before those were invented, I was landing on soft beaches with 3200 tailwheels, and thought they were major cool, compared to the previous iteration. That pic posted earlier isn’t soft sand, by the way..... If you operate for a while and decide you REALLY NEED a bigger tailwheel, buy one, but go out there and try it out first. Baby Bushwheel=heavy and shimmy.
    Main wheel tires are a good investment. As others noted, gear safety cables are mandatory. Borer prop is good.
    Figure red out ways to LOSE weight, rather than gain weight. Good GPS and a sat phone may be good.
    Likes algonquin, mam90 liked this post
    3,030
    Funny, I was reading the shimmy comments wondering why guys don't manage their tails better to eliminate the shimmy. Keep flaps out and hold the tail up until you can't. Problem solved for pavement ops. You won't have any shimmy issues in the "bush".
    The tire equation goes like this. Go push your plane around on the surfaces you'll operate on. If big tires make pushing easier? Use big tires. If hard little tires make it easier? Use little tires and lots of air pressure. Pretty simple. If you're stuck in between? Buy bigger tires and whine about how they wear out on pavement like everybody else does.
    Bush flying means away from civilization. Take the stuff you need to camp out and wait for better weather. A sat phone or Inreach will keep wifey from freaking out when you're late. All said? Communication is the priority over all other equipment. Happy wife, happy life.
    Likes algonquin, jrussl, 68Papa, 46 Cub liked this post
    1,221
    I guess the questions I would ask is how far between fuel stops and what is your load going to be? Three inch gear is good for better AOA and prop protection. I do like the big wheel in tundra/sand, especially when heavy. I carry my bushwheel bag in the back standing up so no leaks. I would rather have big tanks but until I hurt a wing fuel in the back it will be. I would do extended baggage in a heartbeat, it does not bother me to fly at gross. Amazon has lots of nets. Shimmy is a spring issue and that is not a issue if you have a press.
    8,506
    Translation: "Glenn, bring bail money for when Joe and I mess up!"
    Some good points on all the differences with tailwheels. As far as springs getting old and losing camber, that is why there are new ones for sale. Like most stuff, they wear out, get new one and bolt it on!
    Maybe take a trip up here and ride in some of the birds with the mods and get a feel. Going with less mods is actually better, add in as you like.
    9,641
    You guys do understand that David lives in Australia, right?
    Likes cubdriver2, Seaworthy liked this post
    Mar 2013
    Lyons,GA
    43
    Or you all can TRY and follow the monster ...350' one ways...250' waters edge to waters edge Bars....and 300' jack legged slews...and all with a throwaway mount less than $20,000 and 90 HP !
    vimeo.com/249249638
    8,687
    Quote Originally Posted by flyrite View Post
    vimeo.com/249249638
    Cool, you're having too much fun. I hope you weren't being irresponsible and did that on big tires
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    705
    vimeo.com/249249638
    I was scared at first watch. Very spectacular but impressive.
    Then I saw some kind of a pirate, landing on a paradise beach.
    And I was scared again...
    Nice flying, love the video
    17,067
    My 150 hp Super Cub was stock except for the VGs and Dakota Cub brakes when I bought it. I added 29" BWs, Baby Bushwheel and the Borer prop when I first brought it home. I operate on sand and gravel bars every couple of days. Was chewing up the prop on sand and gravel. I sold my 29s and installed 31s. Still didn't have the prop clearance I wanted so I added 3" extended gear. Still get a lot of abrasion on my prop but it is what it is. I use my brothers pod when going places and haven't seen a need for extended baggage when camping for 7-10 days with two people. I did add a B&C alternator because I was coming in from playing at dark and the generator wouldn't keep up. Also added a light weight oil cooler for weight savings. Last year I installed the Thrustline mod for better performance and helped on prop clearance. Recently installed the Sutton exhaust after trashing another muffler, saved weight and opened up the firewall which gets plenty hot in the Texas summer. It also saved 2 lbs. over stock. Removed the spinner recently and saved 2.7 lbs as well. There is a story about how I got most all of these parts. The only thing I bought new was the B&C alternator and it was a special deal through Wicks at the time. I do a lot of scrounging and trading.
    Likes cubdriver2, FdxLou, DENNY, Seaworthy liked this post
    17,067
    As far as the Baby Bushwheel debate, I love mine. Funny when the guys with 3200s come in and it becomes a plow disc and they can't even turn around.
    Sent from my SM-N900V using SuperCub.Org mobile app
    Likes SteveE liked this post
    Feb 2005
    3,256
    Imagine what a 3200 would have been.
    Mar 2013
    Lyons,GA
    43
    Quote Originally Posted by Olibuilt View Post
    I keep my treasure on this river and these sandbars ......Oh.... I got a peg leg too!
    Mar 2013
    Lyons,GA
    43
    Now I know it didn't cost thousands of dollars, but accomplishes the same thing and cannot be torn up.....well.....hard to tear up, and cheap to fix if it does!
    Thanks superbad thanked for this post
    Likes hotrod180, Farmboy liked this post
    May 2014
    378
    That’s some redneck sh**.
    Love it!
    Mar 2013
    Lyons,GA
    43
    If you look right below the N-number ,you can see I agree with you!
    And to the point of the mods needed for backcountry flying. The big tires for me opened the world. It's my experience that the guys with capable bush planes are a lot like my acro buddies in competition, they have the magic feather syndrome .they think if they get one more mod ,or a different mount that it will make them much more capable to the task at hand . Put gas through the tank ,that will make your mount more capable than any mod you can do!
    Meanwhile,...
    4,539
    Just need some seed corn.
    Feb 2009
    67.8N,115.1W CYCO Canada
    729
    I have an Expťrimental PA-12 with 160 hp, vg's, flaps, borer prop, 56-gallon fuel (4 tanks), -18 tail and 3-inch extended gear. I fly on straight floats and wheel-skis.
    I replaced the Odyssey battery in the back with an Earth-X under the front seat. Consequently, my C of G is farther forward than I would like. I need more baggage space, so:
    BELLY POD OR EXTENDED BAGGAGE?
    Likes Seaworthy liked this post
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    705
    Flyrite: Sorry my english. But you seem to be a very funny guy, in the good way. With your flying skills and the look of your flying machine, you should wear a Ronald McDonald costume... Would make some really funny videos!!
    cgoldy's Avatar
    Apr 2009
    355
    Can you tell us about your swamp monster? I am intrigued?
    Mar 2013
    Lyons,GA
    43
    Quote Originally Posted by cgoldy View Post
    So as not to hijack this thread, I started a new thread over under the everything else category titled swamp monster to answer your questions
    Jul 2010
    Fairbanks
    4
    Stock cub, folding front seat, borer prop, tires as required.
  1. Alaskan Bush Pilot Advice
    By cubdreamin in forum Cafe Supercub
    Last Post: 09-11-2008, 05:56 PM
  2. PA-12 STC's and upgrades?
    Last Post: 08-21-2004, 12:52 AM
  3. J-3/PA-11 Engine upgrades
    By D.A. in forum Cafe Supercub
    Last Post: 01-30-2004, 08:40 AM
