Results 1 to 23 of 23
Thread: Cross over vent between independently vented tanks. Yes? No? Why?
    3,030
    Clean sheet fuel system design. Each tank has a Cessna style vent. L-R-Both valve, no header tanks. Do you add a cross over vent? Why or why not?
    What if each tank also has a vented cap, does that change the answer?
    2,844
    I've thought about that often, and the only reason I've come up with is venting redundancy.
    Seems like a good reason, except if one tank's vent becomes inop it won't be apparent to the operator, so then there is no redundancy. Checking fuel tank vents at annual would minimize the likelihood of that scenario.
    irishfield's Avatar
    2,898
    Yes!
    3,030
    Yes with an exclamation point follows why with a question mark?
    Why?????
    irishfield's Avatar
    2,898
    To equalize the pressure in both tanks, to avoid uneven tank usage/flow when on both is the main reason. It's easy with dual vented tanks to create a pressure difference between tanks when flying even slightly uncoordinated. I've been flying mine for 23+ years now. Single fuel tank outlet per wing, vented caps, one ramp air tube for a bit of "push" and cross vented between the upper top of each tank. Have never had the engine cough and I do some pretty weird **** on floats when diving over tree lines into short lakes. Never a hiccup caused by fuel flow.
    Thanks Rick-CAS, Brandsman thanked for this post
    Likes superwyatt55 liked this post
    3,030
    You apparently didn't read the whole question.
    If both tanks have Cessna style vents AND vented caps, does the answer change? We're talking VENTS, not pressure tubes.
    Likes Rick-CAS liked this post
    irishfield's Avatar
    2,898
    Sorry Stewart, been building home builts for 25 years just trying to help you. Carry on..
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,417
    You apparently didn't read the whole answer. Wayne's right.
    3,030
    Not an answer. I'm looking for discussion and hoping for information.
    Rob's Avatar
    Nov 2002
    AZ06
    662
    I'd like to hear more as well, as change in my fuel system is still possible. Anyone who has flown a larger Airtractor will remember the first time they flew without squaring away the rudder trim... The fuel vents are off the outboard end of the wings, and it leaves a spectacular trail off the dragging wing... Proof to the imbalance of pressure. But is that really a problem? I seem to remember the earlier 802's could flame out flying half cocked with low fuel on the advancing wing, but I don't think that had anything to do with crossovers or headers.
    irishfield's Avatar
    2,898
    "Cessna style" vents are ram air tubes! Hate when someone asks for help, then gets defensive and condescending when they don't like the reply.
    3,030
    No, they aren't. The specs for how the vents trail in the lee of the struts are very specific. I've owned Cessnas for the last 25 years. Been there, done that.
    3,030
    The bigger question is why do we use crossovers? Because there's good reason or because that's how we've always seen it done? Standards change. Maybe crossovers are a good idea, maybe they aren't. The real answer is probably in between and depends on other conditions. I'd like to hear the evidence and make up my own mind.
    Aug 2014
    Kenai, Alaska
    135
    I believe earlier Cessna had one hang down vent behind the pilot side strut, and non vented caps. Venting was through the left tank to the cross over to the right tank. AD requiring vented caps changed the whole basic setup, added secondary venting.
    Likes DENNY liked this post
    180Marty's Avatar
    May 2004
    Paullina, Ia
    1,916
    Looks to me like you could get by with no cross over since you may have two vents-----Cessna style and fuel cap. If you use a Atlee cap like I had on the PA12 that had the snorkel ram vent, then I'd say definitely no need for cross over. Some planes just have one tank----you'd have two individual that are connected at the valve.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,417
    As stated in post #5, the reason for the cross-over vent (redundancy notwithstanding) is to balance the static pressure in the tanks. This in turn causes them to feed at the same rate when on "both". In theory they should anyway, but in practice they might not. The location of a vent tube being off 1/4" from it's counterpart might cause a head pressure imbalance that skews fuel draw. The crossover tube solves this. With dual/independent vents in each tank you don't NEED a crossover.
    Likes J5Ron, irishfield liked this post
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,417
    Quote Originally Posted by irishfield View Post
    I'll bet money that the Cessna tube produces some degree of positive pressure. The put it behind the strut to limit the pressure, but I have no doubt its positive to some degree. Champion did the same thing on the Decathlon/Citabria/Scout family but I think they had a perforated cover over the tube.
    Likes irishfield liked this post
    3,030
    Are all airplanes with the "Both" valve equipped with crossovers? Mine have been, but mine have had single vents in each tank so I'm not sure whether the crossover's role is redundant venting or pressure equalization. My suspicion is it's about secondary venting. Many Cessnas have uneven fuel flow so the pressure equalization idea has a flaw. I read an article that suggests the crossover was to provide fuel expansion protection, to give the fuel a place to go without puffing up the tank. I'm not one to fill my tanks after every flight so that's not a problem. My kit has Cessna style tank vents and came with flush fillers and chrome plated killer caps. I had Atlee's make risers for the filler necks and needed caps. Steve instinctively handed me snorkel caps but I asked for standard vented caps since these aren't my primary vents. This is new territory. I've never had dual vents in each tank before.
    I agree Cessna vents must have some element of positive pressure. Negative pressure at a vent would be a problem.
    Here's my Cessna's vent from the service manual. Look at the allowable tolerance. +/- .03" is pretty specific.
    irishfield's Avatar
    2,898
    As you note Perry, of course a tube into the slip stream produces a bit of positive pressure. If it created negative pressure, in the original design with non vented caps, there would have been zero fuel flow in the system on a gravity flow engine without pump.
    Valdez, Alaska
    610
    So, I am no expert on this, but have some recent experience. My exp cub is headerless, off-left-right-both. However I do not have a crossover line. I do have ram air caps. In certain flight/cruise conditions when on both and full fuel I found unequal pressure and if crabbing in the wind some fuel(minimal) is pushed out the cap of the right tank.
    My run run mostly on “both” and have never had a fuel starvation issue in any configuration....a while back I reversed the ram air cap on the left tank, and left the right tank point forward...tanks did not burn evenly, but had no issues over a 3.5 hour flight.
    Not sure how to advance, or if the issue is a crossover. My first cub, a J5 had a crossover, ram air caps and also had uneven fuel burn.
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    602
    It seems like no matter what you do the pressure between the tanks is never perfectly even, and they rarely feed at exactly the same rate when you have both tanks selected. FWIW, I use a single vent under the wing to each tank, with a single pick up at the back in each tank feeding a small header tank located behind the baggage bay. Both tanks feed all the time and there is no crossover vent. My tanks always feed a bit unevenly, but they feed as evenly (or more evenly) as compared to the average Cessna that does have a crossover. The pressure differential is so low as compared to the weight of the fuel, that it really doesn't make any difference. Both tanks will draw down to as low as I am willing to fly them. Since I can get 100% of the fuel without loosing fuel flow, and the differential in feed rate from the tanks is low enough that I can't feel it and it doesn't unbalance the plane, I guess it doesn't really matter for me.
    If you add a crossover vent, it will typically have to dip down below the top of the tank level to cross over to the other tank. So, the first time you top off a tank, that crossover vent will fill with fuel that will remain in the low spot of the line. With both tanks vented to the outside world, you will never see enough pressure to push the fuel up hill out of the crossover line to clear the crossover vent line.
    -Cub Builder
    8,849
    one thing to consider is the cessna caps are vented, but with a valve that only lets air in... i'm thinking those red ones... we used to check them at inspection to make sure they worked
    1,799
    Quote Originally Posted by eskimo77 View Post
    This was the case with the later model Cessnas.
    Earlier models, like my 1948 170 & my 1953 180,
    had a "snorkel" vent up on top of the cabin, tied into the crossover vent line.
    Plus my 180 has vented caps (the "red type") on both side.
    I understand the fuel vent was moved down to behind the strut on later models to eliminate icing over in icing conditions.
    Unfortunately there is an AD that requires this be done with the earlier models if you remove the LH fuel bladder.
    I lkike the vent where it is, IMHO this AD's a solution in search of a problem for a non-IFR airplane, but there you are.
  1. cross feed fuel vent
    By Jack Smith in forum Modifications
    Last Post: 05-12-2017, 06:05 AM
  2. Vented Fuel Cap
    By Fuel in forum Super Cub Sick Bay
    Last Post: 09-20-2010, 11:49 AM
  3. vented gas caps
    Last Post: 04-23-2004, 11:04 AM
