Results 1 to 21 of 21
Thread: "A" Model Experimental?
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    Is there a way turn a PA-18 experimental kit into an "A" model style fuselage? I guess you could maybe reuse an old "A" model fuselage and rebuild it EAB category... I know the "A" model has the flat back, is that just by removing the upper fabric supports or is there more to it?
    A few months back there was an amazing PA18A that was for sale here on the forum that was totally rebuilt, yellow and black with the Flanagan STC for the L19 windows. Love the look of that Flanagan STC.
    I'm walking down the road of making the jump to an EAB aircraft...
    supercrow's Avatar
    Dec 2008
    214
    Sure there is. If it's an ex. fuselage you can do whatever you need to make it as you want it. Reshape the rear deck, window frames or anything else you would like to make as you want it. That's the beauty of going with an experimental. very satisfying to make it your way. If you don't want to bite off a project like that then you have to buy one that suits you. Luck.
    Thanks daedgerton thanked for this post
    Likes NorthcountryPilot liked this post
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    I guess my real question would be what is the main difference between the "A" fuselage and a Stock PA18 other than the flat back where the hopper door used to be...
    supercrow's Avatar
    Dec 2008
    214
    Appearance wise mostly the flat back. If you aren't going to spray with it, any structural difference in the hopper area or elseswhere would be a matter choice. The flat back would be a very easy mod for appearance wise and I agree is appealing to some.
    Nov 2002
    Fargo
    575
    Since I built the plane you lust over I'll tell you , there is a few more structural changes then just a flat back in the hopper area. If you want to do an experimental have Javron make one for you, I talked to Jay a few weeks ago had he was willing to make one for me to clone my last plane but I just bought a Tango cub so that idea is out the window.
    ill post more tonight when I get home
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    Quote Originally Posted by PA-22/20-160 View Post
    Yes sir! You did build the plane I lust over! I figured I could get someone to make a custom fuselage for me. It's only money, right?
    Nov 2002
    Fargo
    575
    If you have a regular fuselage you can cut and weld all the changes in, would take some time but could be done fairly easy. Cubclub has the A-model prints for sale, basically you have to cut the v-brace out and weld in the new tubes on th side change the flap cable routing and add the flat turtle deck archs.
    S2D's Avatar
    Montana
    3,795
    Or since you really aren't concerned about having to reroute the cables to clear a hopper, you can just add tubing as needed to make the shape
    White City, Oregon
    844
    A while back I did a photo series that I Posted on my FACEBOOK page... I know there is a lot of people mad at facebook, but my page is public so you dont have to be a member to view it...
    Ill have to get the photos and repost here later today
    Brian
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    Quote Originally Posted by Steve's Aircraft (Brian) View Post
    Brian
    I just did a quick scan of Facebook, was it the red and white North star?
    Nov 2002
    Fargo
    575
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    Oh man... I wish I had jumped on the opportunity to pick up your plane. Love that look and visibility... Is that "V" brace on the top added since the hopper is removed?
    Nov 2002
    Fargo
    575
    Quote Originally Posted by daedgerton View Post
    Yes that is the structural part of the Flanagan STC to take the load from the rear spar carry through, the glass is just there to add visibility.
    1,313
    If you just want the L19 look you can do that with a stock frame. Did you also want a flat back?
    White City, Oregon
    844
    No... The NorthStar is a whole different bird...
    Here are the photos... I happened to have 2 bare frame Cubs in the shop at the same time when the pics were taken..
    This is a standard airframe with L-21 style glass frames installed, note the V from the rear carry through tube to the center of the airframe..
    This is an Ag airframe... Note the tubing arrangement so that a hopper can be fit... I welded in bracing in this aircraft similar to the Flanegan mod as pictured earlier..
    Standard model upper flap pulley attach point, note that it is inside the airframe..
    The Ag pulley is mounted outside the frame to clear the hopper tank...
    The standard model has a raised baggage floor as seen here by the welded in angles behind the rear seat area..
    Ag model does not have the angles and the floor is all the way down to the lower longerons... The cables are normally covered by hat sections when the tank is removed..
    Standard airframe has a single flap cable routed up the rear V and splits after the top pulley, seen here by the pulley mount location..
    Ag model splits the flap cable before it gets to the rear bulkhead and routes the two cables through 3 pulleys up the side of the airframe... This is for hopper clearance...
    Standard airframe back, has the center stringer and access door the the main aircraft battery located in the top of the airframe...
    Ag airframe... Flat back, no stringer, no access door... The battery was mounted behind the hopper and access was through a small side door behind the main cabin door..
    Brian..
    Likes cubpilot2 liked this post
    17,562
    Couldn't you just do some minor modifications to the former supports and leave the structure alonebto make a flat back? Same with the L21 glass. I saw one done this way somewhere recently if I haven't totally lost my mind. Seen lots of cool stuff and people in the last few weeks.
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    I sort of like the flat back... Chuck’s plane he had for sale a while back just was awesome... I never thought I like the Ag models till I saw that one.
    Nov 2002
    Fargo
    575
    Stock 18 L-21 doesn't look bad ether but my favorite is still the A-model. I'd do another one in a heart beat but they are not always easy to find in the rebuilder price range so you have to go with what you can find. If I was building an experimental then know doubt I'd have Javron build me an A-model fuselage and I thought long and hard about going that route but my planes don't seem to stick around more than a year or 2 at the most. Just don't know if there is a strong market for used experimental Cubs yet so I'll keep doing certified until I'm read to bet my money on them.
    Likes AkPA/18 liked this post
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    in the second picture it looks like the air fliter is the round dome type, did you switch it?
    Nov 2002
    Fargo
    575
    2 different airplanes one is an A-model other is a standard L-21 cub
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    56
    Ahhh. Yep!!! Both are awesome!
  1. Amazing "G" Model Staggerwing
    By Darrel Starr in forum Cafe Supercub
    Last Post: 08-04-2012, 09:05 AM
  2. "model" engines ever made?
    By Jenny S in forum Cafe Supercub
    Last Post: 08-06-2007, 10:58 PM
