Results 1 to 17 of 17
Thread: PA-12 Fuel System and Landing Gear - Tilting aircraft with unwanted fuel transfer between tanks
    Jun 2017
    Sweden
    13
    Hello all!
    I have a PA-12 and I have two issues with it and I was hoping to get some advice.
    1. For some the aircraft tilts to the left. We have changed bungees in the landing gear but still can not figure out why it tilts. It is about 20 cm difference from one wingtip to the other. Has anyone experienced this?
    2. Because of the tilt, the fuel keep on running between the tanks in the vent line. This of course makes the tilt worse and if you have a lot of fuel in it when you park it will fill the bottom tank and push the fuel through the cap eventually, resulting in a waste of fuel.
      Do you think it is a good idea to put some sort of valve on this line so that it can not transfer fuel when it is turned off?
      Could that line be removed or closed all the time? I do not want fuel to transfer between the tanks as standard ops.
    Hope to hear some advice!
    8,039
    Look at the forks which attach the wing struts to the fuselage. One side could be screwed way in and the other side way out. Unscrew both forks on the short side an equal amount and screw in both forks on the long side by the same amount. All of the rigging dimensions will remain the same. Check with a level that the fuselage is actually square with the ground.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,525
    The fuel is pushing across through the supply lines, not the vent. Shut either tank off and it'll stop. As to the tilt, assuming the wings are rigged properly my first suspicion is the bungees need to be replaced. You may have one stretched badly or broken on the left. If it's a stock 12 with the bungees inside the fuselage, it's not a fun job.
    180Marty's Avatar
    May 2004
    Paullina, Ia
    1,962
    Also, assuming it is original landing gear and the rubber bumpers under the seat are up against the stop, maybe measure and see if the gear legs are the same length.
    3,506
    I’d find a hoist or crane and lift it wings level, then slowly let it down and watch what the gear does.
    Is this a new behavior? Do you pin one brake and spin the tail around with power to park?
    Likes moneyburner liked this post
    55-PA18A's Avatar
    Dillingham, Alaska
    547
    You need to resolve the problem of why your aircraft isn't sitting level before modifying your fuel system to compensate for it.
    Have you checked for differences in your tires? Landing gear? Wing struts? Is the fuselage sitting level, with wings not level?
    Please let us know what you find. Too many ask for help with issues, and we never find out if any of the suggestions helped.
    Jim
    Jun 2017
    Sweden
    13
    Thanks, I'll check that!
    Thanks Brandsman thanked for this post
    Jun 2017
    Sweden
    13
    The handbook says that you should have one tank OFF and one ON which I have tried and it is still the same so therefore I suspect the fuel line.
    The bungees has been replaced, actually two times(!), by the previous owner in the last years so I do not think it is that either.
    Quote Originally Posted by 180Marty View Post
    I will do that, thanks!
    Also a good idea. It has been like this for a while, I have only owned it for a year. I do not think it has been turned sharply like that on the same side.
    Quote Originally Posted by 55-PA18A View Post
    Jim
    I agree that I should fix the tilt which also will more or less fix the fuel issue. Soon I am up for the annual and then I will be able to investigate it further. I will get back to you as I go along!
    May 2017
    188
    Have you checked fuselage symmetry? I know of at least one airplane where the fuselage was tweaked and rigging was problematic. Check the diagonal distance across the fuselage at the wing attach fittings to the opposite cluster at the floor.
    Likes mike mcs repair, moneyburner liked this post
    9,902
    I once flew a Cessna 185 that didn’t handle real well on the runway. After first flight, I got back and looked at it, and noted a slight list, as you describe. Turned out that one tire was a Goodyear 8.50 x 6.00, the other was a “brand X” 8.50 x 6.00. Took out a tape and there was an inch and a half difference in diameter. I’ve also seen similar discrepancies in tires both from that same outfit.
    Jun 2017
    Sweden
    13
    I'll check that, thanks!
    9,297
    level top deck & or floor side to side, are they same? set turn & band ball in center now, also in this position in level flight(firewall vertical) see if you have same dihedral on each wing...
    we usually put a valve in any cross vent with a both
    Sep 2004
    Illinois & Wisconsin
    550
    I had the same problem with the 12 I built and the only way I could stop it was to turn the fuel selector to "off."
    If you think about it, fluid in two inter-connected tanks will always seek to level themselves out, regardless of whether one tank itself is placed a little higher or lower than the other--the fluid level will alway equalize over time.
    If turning off the fuel selector doesn't work for your airplane, finding and fixing the reason fuel transfers from one tank to the next is your primary concern, otherwise you will always find yourself with tanks with equal fuel.
    The "why one wing sits lower" question isn't important until you fix the fuel transfer issue.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,525
    The original Imperial valves were of the plug type and somewhat known for not stopping fuel flow in the off position. That was why I replaced mine with the Dakota valve.
    Thanks Brmoore thanked for this post
    Jul 2012
    Montana
    380
    Take another look at the bungles under the seat. Are they the same-examine 'code thread color markings', do both have the same codes, are there the same number of bungles on both sides, do they lay on the saddles the same way.
    12Geezer2's Avatar
    Jan 2006
    Eau Claire, WI
    1,064
    Does it lean to the left ?? Have seen a couple of 12s with "tweeked" fuselage. Stock fuselage is known for weakness on left side. Hard landing will push gear closer to wing fitting. Not sure who has the paperwork for adding a vertical tube from left front gear fitting area to left front wing attach area. Think this is something to do with float mods---?????? Not a 12 expert but there are some here ---geezer Dan--- OH YAH---my 12 will leak fuel out the low wing when parked sideways on a hill---have two fuel valves--both off but fuel will transfer through the vent line between the tanks then out low wing fuel cap vent.
    Jun 2017
    Sweden
    13
    I am on a flying trip to North Cape now but I will check it all when I get back home!
  1. Replies: 68
    Last Post: 08-24-2009, 06:08 PM
  2. Fuel system minus header tanks question.
    By Brent Bostwick in forum Experimental Cubs
    Last Post: 01-02-2007, 01:43 PM
  3. 337 For Using CC Fuel System on 160hp SC with 24 Gal Tanks
    By Darrel Starr in forum Modifications
    Last Post: 03-28-2005, 10:04 PM
