Page 1 of 2 12 LastLast
Results 1 to 40 of 53
Thread: Why?
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    355
    Why?
    Why (often) does the engine start when I release the key?
    And why does it often take 6 blades to start with the key and only one when hand propping?
    I think I have noticed this with cars as well.
    Or am I imagining this?
    One mag and one Emag
    Col Goldy
    storm_pilot's Avatar
    Feb 2004
    Casselton, ND
    128
    Take a look at your mag and ignition switch set-up. In the crank position most ignition switches are set up to utilize only the mag with the impulse coupling installed which retards the timing and increases spark output. Usually this is the left mag. Then when you release the switch both mags fire. You say that you have one mag and one Emag. Where is each mounted? Left or Right? The Emag will produce great spark at low RPM since it is powered by the battery and is programmed to automatically retard timing at low rpm. I suspect that you are running the standard mag on the left and that it may be weak, improperly timed, or that the impulse coupling may be malfunctioning. Personally I would set it up to start on the Emag and eliminate the impulse coupling altogether.
    Buying parts is CHEATING!
    Likes Chicken Hawk, Eddie Foy, moneyburner liked this post
    8,687
    Mags fire better at a slower speed
    1,799
    Starter might be spinning the engine too fast for the impulse to work correctly?
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,417
    You probably have a points-related issue on the impulse mag. The other mag is shunted out while cranking but wakes up when you release the key. If pulling the P-lead off the right mag makes the issue go away, you have your culprit, left mag is dying. CAUTION-- the engine will always be hot with a mag lead disconnected.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    2,447
    Eddie Foy
    "Put out my hand and touched the face of God"
    cruiser's Avatar
    South Glens Falls, NY
    1,310
    To quote from The Magneto Ignition System by John Schwaner “the amount of primary current is determined by how strong and how fast the rotating magnetic field crosses the primary windings”. Page10.
    cgoldy's Avatar
    Apr 2009
    355
    You might be onto something here Hotrod. Since I fitted the light weight prop and earthx batery it cranks faster but does not start as easily.
    Mag on left and Pmag on right and wired correctly. When hand propping I start it on the impulse only.
    8,849
    yup, check your impulse coupling health.. you will break the starter off if impulse fails to engage and retard spark/attempt to kick back....
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,417
    The FASTER the field crosses the coils, the more voltage is produced. Mags get hotter with speed until you reach the point that saturation time becomes an issue. That's why the drag racers use them. As speed increases and saturation time diminishes, induction voltage continues to climb so spark intensity stays relatively constant. With our low RPM engines the spark intensity is hotter all the way to redline. We don't get anywhere near plateau speed.
    Likes Gordon Misch liked this post
    cgoldy's Avatar
    Apr 2009
    355
    All I I know is that it clicks when turning by hand. How else do you check it Mike?
    And that doesn't explain why it fires on first blade when hand propping.
    cgoldy's Avatar
    Apr 2009
    355
    I wonder if my tach reads when starting. I'll check to see what rpm the starter runs it at. Any one know what RPM impuls couplings work up to?
    cgoldy's Avatar
    Apr 2009
    355
    I might just swap the wires on the back of the switch and test if it starts better on the emag.
    7,694
    Quote Originally Posted by cgoldy View Post
    If the engine is turning enough faster the impulse will not engage because it thinks that the engine is already running. The impulse fly weights will be centrifugally disengaged. So the spark will be advanced to the run setting rather than being retarded for starting. That is why it starts when hand propping as it's not turning too fast.
    If you have both a P-mag and an impulse coupled magneto you should remove the grounding connection on the back of the mag/starter switch. Then when you select start, both will be firing.
    Mar 2016
    Vermont USA
    333
    The mag should still fire once or twice as the cranking speed comes up.
    8,687
    I have propped a bunch of engines going back to 1911. 20 hp thru a 400 V12 Liberty. Mag speed is important to generate current. The 50 hp Franklin in the Honroit had to be propped closes to the hub to get enough speed. But others like a B5R Kinner on a Fleet will " never " start moveing the prop fast, starts better hardly moving it. We had an Oliver tractor with a mag that we converted to 12V and it spun so fast it wouldn't start till when you released the starter button and it slowed down. The 400 Liberty just like the 680 in the Stearman fired with one hand slowly pullinging the blade. But what do I know?
    Likes Hardtailjohn, skywagon8a liked this post
    Sep 2002
    Southern NH
    381
    “I have propped a bunch of engines going back to 1911.”
    Man Glenn, you look great for your age! (If I didn’t say it, you know darn well someone would...)
    Mark
    1,221
    Is the mag Slick or Bendix?
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,417
    To my knowledge, they typically disengage at about 300-350 engine RPM. I don't think any starter is going to get past about 200 BUT... If you have weak springs (or one broken) in the IC, that number is going to come down. I'd been thinking about it some more and I think you have 1) an internal timing/e-gap issue in the left mag and - 2) a failing IC. Basically time to overhaul lefty.
    Thanks cgoldy thanked for this post
    Hardtailjohn's Avatar
    Marion, MT
    580
    I was just gonna say....watch someone that doesn't know how, try to start a Kinner!!
    John
    8,687
    Quote Originally Posted by Hardtailjohn View Post
    John
    Most time I'm too stupid to understand the why's and what's that make it work. But I'm lazy enough to figure out what it likes to make it work, my bad
    Likes DENNY, mam90, Hardtailjohn liked this post
    8,506
    That makes you older than EATON! Now I am impressed.
    Likes Farmboy liked this post
    Mar 2016
    Vermont USA
    333
    Quote Originally Posted by mam90 View Post
    Dang, I was just going to say something similar.
    cruiser's Avatar
    1,310
    When someone asks a question about some special technique to get this or that started and the secret start system begins with driving around the hangar in a clockwise direction but under a full moon you must go in a counter clockwise direction or some such BS I always believe that the real answer is basic preventative maintenance. Fuel, air and ignition is all it takes. In the correct proportion. Some folks are too smart for that.
    1,799
    .....If you have both a P-mag and an impulse coupled magneto you should remove the grounding connection on the back of the mag/starter switch. Then when you select start, both will be firing.
    FWIW I much prefer a off/left/right/both key switch with a separate starter button.
    Likes skywagon8a, 180Marty liked this post
    WhiskeyMike's Avatar
    West Boxford MA
    790
    I had this problem after an overhaul and it turned out that the "new" left mag was bad, so it started when you let go of the key to hit both. Make sure it's working. After that the mag check was weird and we weren't getting any drop on right, so we knew something was up.
    Chugiak, AK
    4
    If you have a separate starter button, and 2 impulse mags, is there anything wrong with cranking the starter first to get up to speed and then switching the mag switch to both to start the engine? I know the usual method is to switch on and then crank to start.
    cgoldy's Avatar
    Apr 2009
    355
    I think I am seeing 300 rpm with the starter only. But I have a crappy little tach so hard to be sure that low down. But you might be onto it Perry.
    So just to recap. Last month before I replaced my heavy borer with the whirlwind and lead acid with an earthex and moved the battery location from rear seat to fire wall, she would start on the second or third blade religiously.
    West Boxford MA
    790
    Quote Originally Posted by AK81 View Post
    . That is standard operation in radial engines to get some of the oil cleared out of the lower cylinders to avoid liquid lock. I frequently do it on four-cylinder opposed engines as well when I have a separate starter button I don’t know who invented this key switch start thing but I hate it. For example how in the heck are you supposed to crank a loaded engine through with the throttle open and the mixture lean with the mags off It looks to me like a combination of slick marketing and security theater in that having a key is somehow supposed to keep people from stealing airplanes. That said I also hate cars with a new computer style on off button. it strikes me as one more way to remove competence - and responsibility- from people. Crabbiness aside I’d like to wish everybody a joyous Easter
    7,694
    Colin, That is why I said in post#14 that it is turning too fast for the impulse to do it's job. Try exchanging the P leads on the back of the mag switch so that the mag is shut off and the Pmag is on during starting.
    Quote Originally Posted by WhiskeyMike View Post
    . I don’t know who invented this key switch start thing but I hate it.
    This key start thing showed up when they started using the "shower of sparks" for starting instead of impulse couplings. They wanted to ensure that one mag was dead and that the "shower of sparks" was properly turned on only while the starter was engaged.
    8,506
    Change in prop weight changed the speed it turns, and time to spool up.
    AkPA/18's Avatar
    Big Lake Ak
    609
    Hello Cgoldy
    Is your keyswitch an ACS. If so that is a common symptom of it going bad. I believe there might be a repair kit for that key switch. Also I believe there is a service bulletin or possibly an AD on that switch. This is just from several of my friends that have had that problem. You are not the only one. If not an ACS disregard
    Mark
    http://thrustline.com/
    Likes mike mcs repair, moneyburner liked this post
    8,849
    Quote Originally Posted by AkPA/18 View Post
    Hello Cgoldy
    Is your keyswitch an ACS. ... I believe there might be a repair kit for that key switch. .
    Mark
    http://www.aircraftspruce.com/catalo...?clickkey=7224
    cgoldy's Avatar
    Apr 2009
    355
    Yes! I have an ASC!
    Thanks Mark. The depth of knowledge on this site never ceases to amaze me.
    Col Goldy
    Hello Cgoldy
    Mark
    Thanks AkPA/18 thanked for this post
    AkPA/18's Avatar
    Big Lake Ak
    609
    Hopefully that is the problem. Everything that was written above also makes perfect sense though. Just another direction to try. Your issue does mirror the keyswitch failure---starts on key return and handprops fine. Best of luck. If i remember right there was visible carbon tracking in the switch?
    Mark
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    2,447
    One reason the Magneto switch is coming out of my 180. I prefer the mag toggles and a button.
    Eddie Foy
    cgoldy's Avatar
    Apr 2009
    355
    So if I was to do the same, replace with switches and a button, how could I disable the aircraft to satisfy CASA's. (FAA) security concerns?
    1,799
    "Security" of any mag switches is kind of a joke, since you can bypass them by just cutting the p-leads.
    But I will admit that I am more comfortable with a key switch vs toggles.
    You can't stop a determined thief, but like most locks, they keep the honest people honest I guess.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    2,447
    Put a keyed switch in the master to master solenoid line is one way. A hidden kill switch is another way. Old Cubs have no keys.
    Eddie Foy
    Dec 2004
    Inkom, Idaho
    1,058
    This post makes me realize, that since I went to a mechanical master switch (mounted on the inside firewall, inches away from the EarthX battery) that uses a 16" pushrod with a T handle that I can easily access like the other panel mounted controls, I have failed to placard it's function. Good security I guess, lousy keeping to the regs, even for an experiemental type like me. I do have a keyed ignition also, but the keys, like all my vehicles, stay in all the time. One new placard coming up.
