Thanks Thanks:  0
Likes Likes:  0
Results 1 to 9 of 9
Thread: Air filter options
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    403
    Air filter options
    Getting close to re-building my new Carbon fibre lower cowl/complete cowl. Currently have the traditional round air filter which has given me no end of grief re sealing off the lower cowl and cracking. (O-375).
    What options do I have? I know about the square filter box. This seams like it would be easier to seal. Are there other options for us experimentals?
    Cgoldy
    Back Country O-375 wide body extended wing cub
    8,847
    Quote Originally Posted by cgoldy View Post
    Colin,
    I too have the round filter. What do you mean by "re sealing off the lower cowl"? Are you referring to the baffle which Piper uses to prevent air from flowing past the filter into the lower cowl area? If so, I left that off my plane and found that It wasn't needed.
    I also have had some cracking in that scoop at the aft upper corner. I was able to stop it by placing a glob of silicone adhesive sealant over the crack on the inside. This ties together the metal on both sides of the crack, stabilizes and reduces the stresses which cause the cracking. I blame the cracking on the flexibility of the parts and the use of 5052 aluminum. The 5052 is too soft and not strong enough for this cowl application. The design with this alloy is difficult in a cowl which has high and transitory loads.
    You building a new lower cowl from carbon fiber should eliminate these troubles.
    cgoldy's Avatar
    Apr 2009
    403
    Is this the filter I need order if I want to convert my round filter to a square? Will it allow the O-375 to breath?
    Thanks in advance
    Col Goldy
    4,276
    Air filter options
    You're experimental. Do whatever you can make fit.
    Brackett is old tech. Look at Donaldson if you want airplane parts (washable paper media) , K&N for free breathing (washable oiled cotton media), or any of a crapload of automotive filter suppliers. I went with K&N because they had a filter that met my space requirements and provided maximum flow.
    KelvinG's Avatar
    Jan 2004
    Talkeetna, AK
    213
    Attachment 36968
    Van's has an filter assembly that uses a round K&N filter. http://vansaircraft.com/cgi-bin/stor...t=fab-vertical
    I'm using a Bendix pressure carburetor and needed to make an adapter plate so it would fit. But its an option
    Sent from my SM-P900 using SuperCub.Org mobile app
    "Only a virtuous people are capable of freedom. As nations become corrupt and vicious, they have more need of masters."
    Benjamin Franklin
    cgoldy's Avatar
    Apr 2009
    403
    Attachment 36968
    So do you use a scat hose to connect your filter to your airbox?????
    Oct 2009
    Wanaka,NZ
    324
    Thanks in advance
    Col Goldy
    Colin I have just that setup,no prob.
    8,847
    Colin,
    Converting from the round to the square filter will require some extensive alterations of your air box or just exchange it for one already built for the square filter.
    cgoldy's Avatar
    Apr 2009
    403
    Colin,
    Jay is making me one as we speak
  1. GPS options
    By larrym in forum The Art and Science of Flying
    Last Post: 03-19-2013, 10:36 PM
  2. Air filter, Air filter dome fit
    By Shumaker in forum Modifications
    Last Post: 06-17-2005, 01:28 AM
  3. Round air filter vs flat filter
    By green horn in forum Tips and Tricks
    Last Post: 05-12-2004, 08:15 AM
