Results 1 to 31 of 31
Thread: Tach issues
    jimboflying's Avatar
    May 2005
    473
    Tach issues
    My tach needle is bouncing about 100 rpm and there is some squeaky noise coming from somewhere. What should I do?
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,144
    Tach issues
    Don’t look at it and turn your music up. That’s how I handle mine.
    Likes Ruffair, aktango58, windy liked this post
    irishfield's Avatar
    2,920
    Lube the tach cable before you hear ZOOONGG !
    Likes DENNY, Ruffair, mike mcs repair liked this post
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,239
    They’re BOTH right....!
    "...We're fast enough to get there, But slow enough to see..."
    Fron the song "Barometer Soup". By Jimmy Buffett
    6,381
    And if it is one of those old AC tachs, a good auto speedometer shop can make it like new, set the odometer where you want it, and make you a new cable, all for cheap. Especially if you are experimental.
    18,108
    Sometimes it is the tach and sometimes it is the cable. Have a pretty new Top Cub in the shop and it bounces below about 1500 rpm. Put another know tach in and it works fine.
    4,089
    Has anyone been working behind the panel lately? Sometimes a guy will push the cable aside to get to something, not return the cable when finished, and it binds a little.
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,144
    I shouldn't have mouthed off,,, Mine just broke today, but it was operator error. I swung the engine out to get to the mags and when I swung the engine back in, I didn't pull the tach cable back inside the firewall and it got kinked.... So I get to buy a new one anyway. Maybe that will stop the needle from bouncing, if not I might send the tach in the hospital.
    S2D's Avatar
    Montana
    4,015
    Steve is gonna tear up your logbooks if your not careful !!
    18,108
    LOL, he only calls me when he tears something up. I don't wanna see his logbooks, there is probably nothing in there.
    2,168
    That's interesting....
    I've never seen an E.I. or Horizons tach bounce. Even when the 'cable' gets kinked.
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,144
    I left my logbooks in Montana.
    May 2005
    473
    Just an update. I removed the tach cable, cleaned, and greased it using a light synthetic grease. I did a test flight and found that the flutter of the needle went away. The squeak was from another source.
    Thanks Steve Pierce, marcusofcotton thanked for this post
    Likes irishfield, Brandsman, windy liked this post
    Jonnyo's Avatar
    May 2014
    Fairbanks, Ak
    90
    Hey Guys,
    I installed a new mechanical tack cable a few years ago. Before flying in the Winter at -20, I cleaned out the thick factory grease and put in light synthetic grease. The snowmachine shop in town sells a very convenient, clamp on, cable greaser that made the job a snap. It worked for a while, but the cold still did it in. What is a better system for an experimental? All I care about is the lightest system for compliance with the minimum instrument requirement.
    Jonny
    8,589
    2,168
    Yup. Anything electrical. No cables and the pick up wires go to the mag switch instead of through the firewall.
    Jul 2016
    Anchorage, AK
    85
    Does the cgr 30p monitor rpm with pick up wires?
    2,168
    Quote Originally Posted by vj88 View Post
    Yes it does.
    18,108
    Picks up from your mag switch through the P-lead.
    May 2017
    285
    Quote Originally Posted by Jonnyo View Post
    Hey Guys,
    Jonny
    If you are Experimental AB, and Day VFR, there are no instrument requirements. Your operating limitations only specify compliance with 91.205 if you operate night or ifr.
    Apr 2017
    ND
    55
    I needed to replace my tach. May have cost a bit more than others?, but I really like it. 25694676-3815-4F4E-8C76-9BCA5C4B187B.png94AE8247-39EA-4542-8EB4-2FBAE955002D.png
    8,589
    Another good option. I've had one of these in my 185 for 30 years, it works well.
    10,164
    I had a Horizon tach in my 170 for years and I’d go there again
    2,168
    Horizon tach is outstanding. Just takes a little more real estate than a 2 1/4" model.
    10,164
    indeed, but us old guys can actually read the display.....
    2,168
    Braille version?
    2,168
    But seriously, if anyone has issues reading the smaller displays, use the back lighting. It helps out quite a bit. Also, find displays that have more contrasting colors. Some colors are easier/harder to make out than others, so each person needs to find what works best for them.
    10,164
    My current ride is equipped with one of those ridiculous EI electronic techs with the tiny LCD display and a ring of little lights around the perimeter. To complicate matters, it’s located just above the prop control, as in as low on the panel as you can get.
    Trying to figure out how to improve this without a million $ bill.
    2,168
    Swap it to a better hole? It's just wires on the back, re route them to a higher spot.
    10,164
    Yeah, but to where. I’m cogitating on it.
    8,589
    Mike, Swap it with the instrument with two blue buttons or replace it with a Horizon tach. It appears to be in a 3-1/8" hole with an adapter.
  1. Replies: 3
    Last Post: 02-01-2018, 11:40 AM
  2. New tach
    By i-fly-low in forum Cafe Supercub
    Last Post: 06-30-2013, 07:23 PM
  3. Need a new Tach
    By skukum12 in forum Modifications
    Last Post: 07-23-2012, 09:58 AM
  4. tach cable
    By Tim in forum Tips and Tricks
    Last Post: 01-25-2010, 10:56 PM
