Check this post.
http://www.supercub.org/forum/showthread.php?34474-Sutton-exhaust-heat-robber
Odd, to me, your carb temp readings are so wildly different from mine. 20 degrees ambient and 54 degrees on carb temp my last flight. Full carb heat at cruise power for 5 minutes resulted in no change. I have never seen below freezing temperatures on my carb temp gauge, Jim
Cruiser,Odd, to me, your carb temp readings are so wildly different from mine. 20 degrees ambient and 54 degrees on carb temp my last flight. Full carb heat at cruise power for 5 minutes resulted in no change. I have never seen below freezing temperatures on my carb temp gauge, Jim
Cruiser,
Respectfully, I think there must be something amiss with your carb temp instrumentation. Possibilities might include, connected to a different probe somewhere, wires crossed, wrong connections at the instrument, incorrect location of probe? Dunno, just making wild guesses. However - it stands to reason that the venturi temperature cannot be higher than ambient. I doubt that there is anything wrong with your carb heat box, unless the carb heat control possibly doesn't actually activate the carb heat flapper. That seems crazily unlikely.
But I can't imagine that something isn't wrong for venturi temp to indicate 30+ deg above ambient.
No criticism intended, just thinking about the mechanics of it all.
Thanks, I did. I did not find any reference to induction icing other than a referral to FAR 23.1093, which reads the same, at least for "sea level engines" as CAR-3. That is 90 deg F rise at 75% power.Gordon, look in AC-23-8C. Flight test guide. The instructions for all testing is there. As I recall there is a condition when you add 100* to the calculations.
Well, here are a couple of things - -
I flew again today, with the cabin heat hose connected to the carb airbox. 1200 ft MSL, OAT 40, normal cruise at 2400 RPM, carb temp 18 without heat, and 41 with heat. 23 deg rise, as compared to 16 deg rise from the carb heat side of the shroud. I was surprised; I expected more temperature gain. But there's the data.
From the information Skywagon8a provided, the regulatory temperature rise is to be measured at the heat source discharge, upstream of the venturi. My carb heat transducer is downstream of the venturi, and upstream of the throttle plate. I think that port is standard on the Marvel Shebler carbs. So I am a little bit uncertain about how to compare that regulatory rise to the rise observed at the carb temp sensor. I think, emphasizing 'think', that the delta t between carb heat and no carb heat should be the same at either location, i.e. upstream or downstream of the venturi. But it's been too long since studying thermodynamics of dynamic fluids, so I'm uncertain. Any of your Thermo / Fluids guys able to shed some light on that?
Bottom line though, increasing the carb heat contact with the muffler certainly did increase the carb heat effectiveness. So I'm thinking about the possibility of adding some baffling to the muffler on the carb heat side, to increase that contact. As STC'd, the carb heat air has a very direct path in the muffler shroud from inlet to outlet. The contact with the muffler surface is minimal.
Edit: Another aspect of the info Skywagon 8a posted, is the OAT when measuring the temperature rise across the carb heat system, is to be -10 deg C. That is 14 deg F. At that lower ambient temperature, the temperature rise across the carb heat system would be greater than with an OAT of 40 deg F. Reason being, greater delta t between muffler surface and air. So the temperature rise I should expect at 40 F, would be less than the regulatory rise. But not hugely less because the EGT and muffler surface temp is so much greater than the ambient temp. I did not check EGT's today, however.
I'll have to check. You've given me a good excuse to go fly some tomorrow.soooooooo..... what sort of EGT temp you got to rob the heat from??? maybe not much to rob from???
It's hard to tell detail from the drawings, but it seems clear that the inlet/outlet ports are arranged differently on the shroud. It appears the Citabria shroud would provide more hot-surface contact for the carb air.Citabria exhaust: https://www.acornwelding.com/product...20Citabria.pdf
Sutton exhaust: https://www.propilotsinc.com/exhaust-conversion/
Compare the two and the inlet/outlet setups.
The temperature probe in your carburetor is measuring the temperature of the fuel/air mixture after the cooling effect of vaporization. This probe is only telling you of the potential of ice in the section of the carb where the ice accumulates restricting air flow. The heat source must raise the temperature above the vapor cooling temperature plus enough to melt any formed ice.....the regulatory temperature rise is to be measured at the heat source discharge, upstream of the venturi. My carb heat transducer is downstream of the venturi, and upstream of the throttle plate. I think that port is standard on the Marvel Shebler carbs. So I am a little bit uncertain about how to compare that regulatory rise to the rise observed at the carb temp sensor. I think, emphasizing 'think', that the delta t between carb heat and no carb heat should be the same at either location, i.e. upstream or downstream of the venturi. But it's been too long since studying thermodynamics of dynamic fluids, so I'm uncertain. Any of your Thermo / Fluids guys able to shed some light on that?
That is the answer. Bend up a Z section of stainless, spot-weld (preferred) it to the shroud to force all of the air the long way around. It can be riveted but be cautious that they do not work loose enough to be ingested into the engine. Perhaps there is some high temp adhesive which will prevent rivets from working loose? Screws and lock nuts could also be used.Distance? Look at my previously posted pictures. The distance is zilch. The hose to the carb heat box is directly adjacent to the air inlet. The air flow assumption is that it all sort of swirls around the #2 and 4 pipes and the end of the muffler can to absorb heat and then comes back to the hose to merrily flow to the carb heat box. I picture the air flow going to the carb heat box directly from the opening to the hose.
