Page 1 of 3 123 LastLast
Results 1 to 40 of 97
Thread: Exhaust Advice
    Feb 2004
    58
    Exhaust Advice
    Nearing completion of a PA-18-150 rebuild and looking at exhaust upgrades. I am leaning towards the Sutton exhaust but thought I'd ask for advice. I like the lighter weight if the Sutton and they report better heat in the cabin. Any comments or suggestions?
    RaisedByWolves's Avatar
    Feb 2005
    3,615
    Sutton is great. Cleans up the firewall, lower engine temps, heater works great, gets rid of the ad too.
    Thanks tbone thanked for this post
    Likes tbone, Bearhawk Builder liked this post
    cruiser's Avatar
    South Glens Falls, NY
    1,410
    Found my exhaust studs too short to get a full nut with a flat and lock washer due to the flange thickness. Had -13 studs installed and problem solved. Other than that just as RBW said.
    17,995
    Just installed the Sutton exhaust. Lost 2 lbs, didn't gain any performance but like it for same reason Tom posted above. Here are some pictures.
    http://www.supercub.org/forum/showth...tion-and-PIREP
    I have installed several Hot Rod mufflers, they do get some more rpm but are loud and heavier and you don't get the benifit of not having a crammed firewall.
    Feb 2005
    3,615
    Really loud inside with the door open in flight. Loud with it closed too
    Feb 2004
    58
    Anyone else found the Sutton exhaust to have noise issues?
    jrussl's Avatar
    Jul 2005
    Madison, WI
    465
    Quote Originally Posted by gli77 View Post
    I think they are referring to the Hot Rod exhaust, not the Sutton.
    I like my Sutton a lot. 800 hours on it since my rebuild. No noise issues.
    Jeff
    17,995
    I think the Sutton is a bit louder than the stock system I just removed but not near as loud as a Hot Rob muffler.
    Feb 2005
    3,615
    Has anyone cut there sutton down or used the angle adapter to keep the exhaust off the tire and gear leg?
    Tom
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    402
    Great exhaust system. I started with the curved adaptor but had discolouring on the fabric so I changed to the straight. Haven't noticed any signs on the tire but some on the gear. Can't have everything I suppose.
    Meanwhile,...
    4,797
    Tom
    Like this?
    Feb 2005
    3,615
    Like this?
    Yeah, got any more pics? Keeps the exhaust off the gear leg and step?
    Dec 2016
    Canyon, tx
    277
    Tom
    Ha ha.....A couple years ago you were worried about the fabric falling off. Now you’re worried about exhaust getting on your new paint. Champagne problems! Hurry up and run some brush thru your tailfeathers so you can go back flying instead of primping
    Likes cubdriver2, skywagon8a, Iflylower liked this post
    Feb 2005
    3,615
    With the amount of labor i put in this stupid cub id like it to be nice for a while.
    Likes 40m liked this post
    Meanwhile,...
    4,797
    I checked the tire with a ir temp gun and didn’t have any excess heat, I do get some discoloration on the gear step but it scrubs off. Be sure to order it with the removeable extension otherwise you’ll need a 3 pound coffee can for a template when you cut the cowling.
    Feb 2005
    3,615
    Exhaust Advice
    I got it to fit good with the full length tail pipe. Haven’t cut it yet. Had the Sutton before the rebuild. It’s great.
    Apr 2018
    10
    Quote Originally Posted by jrussl View Post
    Jeff
    We might be needing a new exhaust soon for the plane. Just finishing the installation of new rack and tonneau cover we ordered from 4WheelOnline for kayak mounts on the truck. Heard too how loud the Hot Rod exhaust is.
    Dec 2016
    Canyon, tx
    277
    That is a pretty clean belly. Maybe you need this exhaust tip.....
    6,344
    Whatever you do, get that letter for an AMOC. Fifty-hour disassembly is expensive and can cause damage. I just pulled a 900 hour muffler with a cracked outlet. We got the Atlee Dodge muffler replacement. CC took the Sutton off when they installed the 180 hp. Nobody ever told me why - maybe it didn't fit the bigger engine?
    Valdez, Alaska
    624
    I really enjoy my Sutton Exhaust...one benefit I like is it also kicks the exhaust out far from the cabin, which means no CO...yes Yellow exhaust stain on gear...but easily cleaned with simple green. As for noise I feel it is not too loud.
    Thanks Carl Guilliams thanked for this post
    Eddie Foy's Avatar
    Dec 2014
    2,994
    I think you mean no CO. CO2 is what you exhale.
    Quote Originally Posted by J5Ron View Post
    I really enjoy my Sutton Exhaust...one benefit I like is it also kicks the exhaust out far from the cabin, which means no CO2 ...yes Yellow exhaust stain on gear...but easily cleaned with simple green. As for noise I feel it is not too loud.
    Likes J5Ron liked this post
    2,288
    Does anyone know why Sutton puts on such a long tailpipe?
    Is it supposed to be a "tuned" length?
    I've seen several installed with the tailpipe cut to a more convenient length.
    3,137
    They told me it was to get exhaust gasses well away from the cabin, and that it could be shortened if desired. I don't recall how much I was told it could be shortened, and I've left mine full length.
    Eddie Foy's Avatar
    Dec 2014
    2,994
    According to Sutton, It can be shortened three inches or shortened to a minimum of three inches. I forget which.
    Feb 2005
    3,615
    min of 4" protrude through the bottom of the cowling
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    1,810
    Exhaust Advice
    NAPA aircraft and exhaust parts.
    http://www.qtponline.com/products/ex...tip_59308.html
    Feb 2006
    Maine
    742
    Tom, You need to get JB some mothers and put her to work on that air cleaner dome in all her spare time.
    1,498
    Both my stock and Hot Rod mufflers made lots of heat No problems even at -30. I do have a heat robber on front also. The Hot rod is loud as mentioned and fire wall space is tight. I do thing the Hot rod helped with lowering CHT's a bit, and a bit more power on climb out. I would be happier if is was not as loud.
    Thanks Beaverpilot thanked for this post
    Oct 2006
    Seldovia, Alaska
    122
    Does any one have any knowledge as to how to increase carborator heat with the Sutton exhaust?
    Perhaps a scoop to increase air flow or a restriction to prevent air from moving too fast and not heating adequatly? I’ve heard that springs around the pipe under the carb heat tap will increase heated area.
    Thanks cruiser thanked for this post
    17,995
    Quote Originally Posted by reliableflyer View Post
    At what OAT temp do you not get enough carb heat?
    Oct 2006
    Seldovia, Alaska
    122
    Im in the process of building the plane and getting ready to hang the engine. I don’t know that it will be lacking carb heat, I’ve just heard roumors and anticipating how to make the system as efficient as possible.
    17,995
    I have the Sutton exhaust and maintain quite a few Super Cubs with it and know of a lot more on Pacers and Clippers as well and have not heard of any issues with the carb heat. Being in Alaska I definitely get the heat ribbons.
    3,137
    I have the same problem with carb heat on Sutton. Smooth surface muffler. I added some muff inlet restriction and that helps but it's still marginal at best below mid 20s OAT.
    6,344
    What I loved about it was ease of installation, no muffler AD, and lots of room behind the engine. Did not notice any performance change or excessive noise.
    Should I be using lock washers on my brass exhaust nuts? I have lost studs, but never lost a nut.
    of interest - CC converted the a/c to 180 hp, stock exhaust, and kept the almost new Sutton stuff. I insisted on an Atlee Dodge muffler - I absolutely hate doing that AD on a Super Cub. Hate it!
    17,995
    Hmm, I have not heard of this issue. Of course it rarely gets in the 20s and when it does and I am flying it is pretty clear and I don't remember pulling carb heat. Has anyone asked Brian Sutton about this? I wonder about closing the end of the shroud and putting pressurized air to it.
    3,137
    Sorry to admit, I have not.
    cruiser's Avatar
    1,410
    Would be interested to know if this is a ram air type system or suck air by the tubes and end of the muffler design of the Sutton.
    Oct 2006
    Seldovia, Alaska
    122
    Gordon did you place the restriction on the air inlet to the muffler heat shroud (a single 2”) or the outlet, just past the heater and carb heat connections (two 2” outlets?). If it was the outlet what percentage of the outlet did you restrict?
    Steve, have you seen a difference between those exhausts equipped with the heat ribbions and without? I have those heat ribbions on mine but I don’t remember if that is the later version or if I ordered it with some cold weather kit.
    Oct 2006
    Seldovia, Alaska
    122
    It also appears that if one shut the cabin heat off when the carb heat is applied the carb heat would get more hot air.
    cruiser's Avatar
    1,410
    I do not believe this is correct. The cabin heat is taken off the entire muffler under the can via Ram air. The carb heat is taken of the end of the muffler, outside of the can, and off a small portion of the left hand exhaust stacks under the small shroud. No ram air. This is a view of the carb air intake. Now if a guy was creative, and non certified, I suppose a Y tube could be used in the cabin heat duct to provide fully muffler can heated ram air to both cabin and carburetor heat.
  1. Replies: 14
    Last Post: 12-15-2015, 04:23 PM
  2. Leading Edge Exhaust -- Exhaust Odor in Cabin on Final
    By Darrel Starr in forum Cafe Supercub
    Last Post: 06-01-2011, 10:02 PM
  3. need PA 12 exhaust advice
    By akpepperdog in forum Super Cub Sick Bay
    Last Post: 03-09-2005, 09:52 PM
